I'm reading that this case has problems with larger power supplies...
Yes, I run an Armor 8003 + 750TX. No issues at all really. Any issues in particular you read about in regards to this PSU?
Yeah, its because if you mount the top side blowhole fan and your PSU is too long you wont get both of them to fit in there together. But if you take out the blowhole fan and the clamp that holds it in you should have no issue.
Is that going to make a difference in cooling ability? Half the reason I was buying this case is because its huge, and gets great airflow. The other half is just that it looks damn cool
