The Hunter
- May 29, 2002
Okay, well I've been looking at laptops to get for university in the fall, and the current front runner is a Dell 600m. It's not perfect, and I'd love to have a nice T42 or something similar, but I just can't justify the expense for an IBM.
So far, this is how it's configured
1.5 GHz P4-M
14.1" XGA w/ Radeon 9000 (not great, but I'm not going to do any intensive gaming)
1 stick of 256 MB DDR 266 (going to throw in another stick of 512 that I can buy elswhere for less money)
40 GB HD
8X DVD+R w/ dual layer (free upgrade, woot!)
v.92 modem + 10/100 NIC
Intel PRO/Wireless 2200 802.11b/g
It meets what I need, it's relatively light (5 lbs), and it's a reasonable price. I've got a few questions though.
I like to avoid all the OEM crap that comes with freshly bought computers. So what sort of OS comes with Dells? Is it still some stupid recovery CD that puts on all the junk, or do they by some stroke of luck come with a real windows CD? Also, I can get a cheap copy of XP Pro from my university, but it's an upgrade copy. What do you need to install an upgrade copy? Can you just give it a CD key and do a fresh install, or does it have to be installed on top of an existing install?
Second, what is the performance on the P4-Ms? I thought I read somewhere that because they have a different core design than normal P4s, you get much better performance with an M than a similarly clocked desktop P4. Is that true, and what would a 1.5 M be equivalent to?
Finally, are there any huge problems with the 600m? Or is it generally an alright computer?
1.5 GHz P4-M
40 GB HD
