rogue_jedi
- Sep 6, 2002
in my copy of ut2004, my keyboard/mouse will periodically stop responding. the game keps operating, however. it just ignores input for a little while, and has me moving in the same direction. then, it just jumps to where i would have been had it not done anything wrong. at least, that is what i think is happening.
both my keyboard and mouse are connected on usb. i have a rev1 a7n8x deluxe with a 35W 2400+ mobile. (this happens no matter what the chip is at, and also happened on a 2100+ palomino at stock) the motherboard had a little water spilled on it, but seems fine, albiet a little more tempermental than it used to be. could the usb controller be going? or is it a software problem? it isn't the engine (as far as i can tell) because ut2003 works fine, and without glitch, even with my '"lightsaber" mod turned on (it works best with instagib mode... i used a custom config mod that allows you to change weapon characteristics, then set the firing rate on the shock rifle insanely high. fun stuff) but anyway. any ideas?
tia.
tia.
