When assigning the backup selections, is it necessary to backup user mailboxes AND the information store? OR can I do just one and not the other?
Here is my problem: For some reason the BE engine is kicked offline and the backup keeps going (automatic cancellation won't work with BE engine offline).
The only thing in the logs shows that it had problems when it got to the Exchange Information Store.
BE can backup everything else. I had an employee do some research on it, and he says everything he found pointed to the Information store being corrupted....yet everything seems to be running just fine.
Should I run the ESEUTIL later anyway?
This is Veritas BE v. 9.1 rev 4691
Edit: Haha. I'm an idiot. After some research I found my answer.
