From Core Temp site:Skunt said:On Coretempt, it shows my Tjunction temp at a staggering 85c. Is that normal? My cpu idle temp is 40c.
[/font][font=Arial, sans-serif]Intel defines a certain Tjunction temperature for the processor. In the case of Yonah it is 85C° or 100C°. First of all the program reads from a Model Specific Register (or MSR), and detects the Tjunction temperature. A different MSR contains the temperature data, this data is represented as Delta in C° between current temperature and Tjunction.[/font]
[font=Arial, sans-serif]So the actual temperature is calculated like this 'Core Temp = Tjunction - Delta'[/font]
[font=Arial, sans-serif]The size of the data field is 7 bits. This means a Delta of 0 - 127C° can be reported in theory. But from preliminary tests, the reported temperature doesn't go below 0C°, no matter what kind of cooling was used.
