Quote:
Thermaltake Tsunami
QX9650
GA-X38-DQ6
4gb Patriot Viper PC2-8500
X3 1,000Watt modular PSU
1 x Asus EAH3870 X2 1gb
1 x Visiontek HD 3870 512mb
Coolit Koolance thermoelectric coolant chiller using
6 peltiers keeps the CPU at a constant 31c and the case at 35c.
Additionally the case has 4 120mm fans
Graphics are cooled by stock fans, the Coolit and 4 additional fans
3dMark06: (w/o crossfire working): 18,574 See http://service.futuremark.com/compare?3dm06=7318144
Also you mentioned that without crossfire you get that ^ 3dmark score....I don't know much but how can crossfire 2 different graphics cards? I know they are both 3870's cores...but memory and design??? How does it work out?
ok....can I SLi a 8800GTX and a 8800GTS? Or more likely in my case....can I SLi a 9600GT and 8800GTX?
Then how can a 3870x2 and 3870 512mb be crossfired? Isn't it the same as the previous post I posted?
