WickedWeasel
- Jul 13, 2004
Gigabyte P35 mobo
E2160 processor
Ninja heatsink
1.8 GHz running at stock, no overclock
opening the case does not change cpu temps
Idle
Easy Tune 5 system 38 degs, CPU 33 degs
SpeedFan 4.29 temp1 38 degs, temp2 34 degs
Intel TAT CPU0 40 degs, CPU1 42 degs
core temp 0.95 core0 38 degs, core1 42 degs
100% load using TAT
Easy Tune 5 system 39 degs, CPU 53 degs
SpeedFan 4.29 temp1 39 degs, temp2 53 degs
Intel TAT CPU0 60 degs, CPU1 62 degs
core temp 0.95 core0 61 degs, core1 62 degs
it is confusing because easy tune 5 matches speedfan and TAT matches core temp.
does TAT and coretemp give 15 degs higher because of the 85degs to 100degs change?
do i have to deduct 15degs because of the E2160?
temps around 60degs at load seem too high for stock settings.
the heatpipes on the ninja aren't even warm
the northbridge is warm though
E2160 processor
Ninja heatsink
Idle
100% load using TAT
