Okay. Something has been terribly wrong for the last few weeks. It all started when a 750GB drive died that I had my OS installed to. That was bad. If you take a drive from the drive pool and plug it into a computer it shows up as a HDD labelled 'DATA' and (once you allow viewing hidden files) you can see whatever data happened to be on that disk, and you can transfer those files wherever. It's not pretty but you can get the data.
Now, once the OS was unable to load I bought a new 1TB and installed WHS to it. I noticed right away that everything was slow. I figured maybe it was because I reduced to stock clock speeds but after increasing them to 3GHz it didn't make sense. When I click on the WHS Console it takes like a minute to load. Switching between tabs in the console takes like 10-30 seconds, maybe longer. I installed the Disk Management tab and it takes forever to do anything with, and no longer tells me my disk activity or temps. After a couple weeks of getting the data off of my drives, I grabbed the data that was on the untrustworthy 750GB. Everything was fine. It never had a problem again, I was able to unload all 750GB and no errors. I liked it so much that I put that drive back in the new storage pool. Well after moving another 750GB to it, I could hear my RocketRaid's alarm go off and it tells me the drive is dead once again. Joy. So I'll worry about that data later, but in the meantime I cleaned off my 1TB and installed Windows Home Server to it again. Installed all drivers, Power Pack 1, and all updates, and it's still mega slow! And I mean, slow. Transferring data between drives is fine but when you drag a window around it takes a few seconds to load the window, regardless even 'My Computer' or something. It's very strange.
I'm getting a conflict in one of my folders, I don't know if you guys have seen the 'File Conflicts' window ever show up? The status cannot be cleared no matter what you do, I had to deal with it for 6 months one time before I reloaded WHS. Moving 16TB around to fix an error label is quite a task, but it's happening once again. It says it cannot move the files into the folder but it doesn't make sense because I did not transfer the data any more different.
Regardless, let me know what you guys think, in the meantime I might install XP or Server03 in the meantime. I sure miss having the drive pool and all the fancy folders, but it's taken me weeks to try and fix this problem and every time I have to move 10-12TB around and it's just not worth it.
