ubern00b15
- Oct 18, 2003
I have a linksys WUSB11 Version 2.8 card that I am using to connect to my D-link 54G router. I get decent connection strength, but I have to use the windows utility to connect, and every ten minutes, it looses connection, which is really annoying. is there any utility i can download for my card that is better then the piece that came with windows? I have windows XP by the way
Router
USB Card
Router
USB Card
