NickJames
- Apr 28, 2009
Looking to trade my EVGA Classified X58 E760 for an ASUS Rampage III Gene X58 board or $140. (make an offer)
ALSO LOOKING TO BUY ASUS Rampage III Gene X58 LGA1366 WILL PAY CASH (ANY CONDITION)
WATERBLOCK SOLD Board still available.
My board
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188048
Board I want
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131658
Board is fresh from an RMA so it's in excellent condition and was never installed after with pretty much all original accessories in original box minus a SATA cable or 2, includes all 3 different SLI bridges, I/O plate, USB 2.0 PCI plate, IDE cable.
[Strike=Option]The Koolance Waterblock comes with (2) 3/8 Koolance compression fittings. There is some red staining inside the WB from some dye I used which didn't get cleaned out of the loop properly so you may want to run a cleaning loop first or open it up to clean it out (it may be pretty bad in there but it functions fine, gets NB temps from upper 70s to mid 40s. The compression caps have some rust from improper storage (never put wet compression caps inside a ziplock :|) but I cleaned and boiled so it's not to big of an issue since it's only on the inside and mostly cosmetic.[/s]
I am looking for an ASUS Rampage III Gene X58 with original accessories aswell (or atleast most of them, we can work something out if it's in good condition)
Thanks for looking
Also pics.
Pic of board installed in my old setup.
My board
Board I want
Thanks for looking
Also pics.
