Any of you have any tricks for solving STOP 0x0000007b BSOD?
I thought to do clean install of XP Pro to go along Win7 64bit in case of problems with old games. I intended to put it into fast RAID10 array of 3ware so naturally I "nLited" required driver into XP disc (along with ICH's drivers while at it) and installation program find array correctly and all goes well until installation files have been copied and PC restarts for final setup which aöways results that same BSOD with exactly same error always...
After further updated and tweaked SP3 disc I've tried it with just SP3 and SP2 discs with driver integrated and also tried changing BIOS settings, disabling various controllers and even removing some devices mentioned in some posts regarding this same error and nothing changes the slightest detail of error.
That's while at the same time installation of Win7 went smoothly and it works perfectly from RAID array like also all hardware does in everything I've tried in Win7!
So hardware fault can be in practise excluded.
Also if I connect one drive to motherboad then installation goes fine regardless are ICH's ports in IDE mode or driver requiring AHCI mode so looks like XP is just screwing it up for some reason and not wanting to boot from 3ware.
