faugusztin
- Mar 9, 2008
Hi,
i bought a Yate Loon D14SL-12 fan, supposedly 140x140x25mm fan. What was my surprise, when i tried to install it - it didn't fit. Then i measured it, and actually it is 135x135x25mm fan. What is a bigger problem, mounting holes are not 125mm but 120mm away from each other. In other words, drawing at Yate Loon page are not true for my D14SL-12. To be exact, no product at Yate Loon page fits the product i bought.
Is this a faulty product, faulty series, or i just misunderstood something ? The only thing i can blame on is the extra type number - my fan is D14SL-12 (L-S01).
Here are some photos of it :
Edit: i googled a little bit, and it looks like fake product. Looks much like FD1325 SERIES fan. 11 blades vs 7 on other Yate Loon pictures, the size, the shiny effect of the backside. Someone probably took this fan (looks very close to 14cm when not measured) and put Yate Loon sticker on it.
Edit2: And here i found probably the source of my fan, but still it is questionable why it is only 135mm instead of 140mm with 120mm holes instead of 125mm holes :
http://www.caseking.de/shop/catalog...ef=115?tduid=044557b8ea0ead903b64df881f1f4172
