I have built about 9 of the computers listed below for work. These are for 3DSMAX, CAD, and basically all sorts of other 3D work. So far everyone that has one (unfortunately i don't have one) has absolutely loved the computers. They have also been added to our render farm during none working hours and cut render times down significantly!!! I just wanted to see what people have to say about the builds.
Keep in mind this is about performance and these will not be overclocked, ever! SLI is not an option. The graphics cards have to be NVIDIA, not by my choice (I would try to get a few ATI's) but because that what one of our main partners uses and so that is what we use....
Anyway here is what I have, let me know what you think:
Case: CoolerMaster 690
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119137
DVD Burner: LG 22X SATA
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136152
Hard Drive: WD Caviar Black 640
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319
Power Supply: PC Power & Cooling Silencer 750
http://www.newegg.com/Product/Product.aspx?Item=N82E16817703009
Motherboard: ASUS P6T Deluxe V2
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131365
CPU: Intel Core i7 940
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115201
Memory: 6 x 2 GB (12 GB Total) GSKILL DDR3 1333
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231230
Video Card: XFX GTX 285
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150334
OS: Windows XP x64
One of the computers has the following sound card and is being used as an audio/video capture machine:
http://www.newegg.com/Product/Product.aspx?Item=N82E16829102015
OS: Windows XP x64
