response99
- Oct 22, 2006
The Zalman 7700 or the 9500 best for the buck? what you guys think about these two fans
response99 said:The Zalman 7700 or the 9500 best for the buck? what you guys think about these two fans
Zero82z said:The 9500 is far better, but something like a Scythe Ninja would perform better than both for a lower price.
jon67 said:Depends on your case design. The 9500 has better heat conduction (lower delta T) than 7700, but it sucks air from the front to the back so the CPU cooling effect will depend on the case air temperature. The 7700 sucks air down towards the motherboard, and if your case has an opening in the opposite side panel (like mine) you can make/buy a duct and lead outside air directly onto the CPU heatsink, before it is mixed with the warmer air inside the case. This way you may be able to get lower CPU temps with a 7700 than with a 9500.
