faugusztin
- Mar 9, 2008
Hi,
bought this card for PhysX/CUDA processing (my main graphics card is HD5870).
The card - Zotac GTS250 Eco 512MB :
http://pden.zotac.com/index.php?pag...category_id=71&option=com_virtuemart&Itemid=1
Card measurements :
The problem :
1) the original cooler is very poor, it's noisy over 45%, plus in my dual card combination (HD5870 for game and GTS250 for PhysX) it runs @ 3D freq all the time, even in desktop (i'm able to "counterattack" this by under-clocking through Riva Tuner). Temperatures with original cooler are ~70C in "idle", ~80-90C when used. I tried to replace the fan with a Scythe Slip Stream Slim (120x120x12mm, 800RPM), it keeps +/- the same temps but with a lower noise. Still not the best choice, 90C is not something i like to see. Maybe i should try some of the 120x120x20mm fans (i can get a Yate Loon), the question is how big impact will it have with that small aluminium block used as cooler.
2) any aftermarket cooler can be max dual slot.
3) Accelero coolers (~1cm over the limit in case of S1), Thermalright coolers doesn't fit or are incompatible, neither does fit GFX Chilla (2mm over the limit, GFX Chilla is 161mm long and has the GPU block exactly in middle). In addition to that, i'm pretty sure Accelero is unable to handle GTS250 in passive. Scythe Musashi is bigger than 2 slots, so it is not acceptable either.
The only alternative i found so far which would probably fit is Scythe Setsugen, but that cooler is bloody expensive, bad availability and has poor results compared to it's price.
Any ideas ?
PS: Please don't suggest water cooling
Card measurements :
The problem :
Any ideas ?
