(cf)Eclipse said:not really a procedure, but here's what i did
http://www.hardforum.com/showthread.php?t=851884
http://www.hardforum.com/showthread.php?t=857220
one warning.. be careful if you go through with it.
(cf)Eclipse said:and when you put the heatsink on.. well first, make sure your core is flat, mine wasn't.
but when you put on the heatsink, find a way to compensate for the lack of ihs. otherwise there won't be enough pressure for effective thermal transfer, however, don't create too much pressure because as purefun said, your core may break.
(cf)Eclipse said:no, more as5 would negate the purpose of removing the ihs: better temps
and besides, you won't be able to make the layer as thick as the ihs.. it's about 1-2mm thick
i just bent the mounting bar on my zalman.. if you can't figure out a way to make it tighter before you go ripping the lid off, don't do it.
laserbeam said:Looking at my HS it can be done. However, doing that and getting even downward pressure onto the cpu will be an interesting challenge. Also, the S939 CAM looks like it would snag the HS faceplate (the core may be lower than the CAM).
This isn't something I want to rush into anyway. I'm still not sure if I have an underperforming memory controller on my PCU or not. Will find out next week when I get my memory replaced (OCZ 4000 VX - yummy
MaMMa said:I'm now wondering about your OCZ 4000 VX, have you read this? If not read it and read it well.
helpful
