That's a nice OC, cept I don't think you can get any game to run without crashing unless you got some special cooling. Max i can get my asus 5850 is 1035 core 1200 mem, max volts. and that's just a few runs of Vantage. Load up Streetfighter or Batman and it locks up after a few runs. But, ...maybe yours is special....HD5850 is fast. Over at HWbot this is how I'm doing with the HD5850.
Try lowering the voltage a bit and cranking the fan to 100%. I'm assuming the 5850 behaves identically to the 5870 and its stability is heavily dependent on temperature.That's a nice OC, cept I don't think you can get any game to run without crashing unless you got some special cooling. Max i can get my asus 5850 is 1035 core 1200 mem, max volts. and that's just a few runs of Vantage. Load up Streetfighter or Batman and it locks up after a few runs. But, ...maybe yours is special....
Thing is, if you are using Vista or Win 7 with aero, if you open up alot of webpages at a time, the card will kick into full speed, and the temps will spike up, thus making your fan spike.
Very nice utnorris.
Things are going well for my over clocking on the HD5850. I'm seeing easy boost in frequencies. Just not seeing the performance outputs I expected. I was hoping to break at least 17,000 with my clocks below.
1000/1200
http://www.techpowerup.com/gpuz/uhq2p/
Is your card Furmark stable at 1Ghz? How loud does it get?
Oh, I wouldn't recommend it for daily use, but some people are really into maximum overclocks, and that would be the way to do it. Personally, I don't like hearing excess noise above an almost inaudible hum from my PC. Hence I leave my card on stock volts with a mild overclock, and the fan rarely exceeds 30% fan in games . Also, don't worry about variable fan speeds. Most wear on fans comes from stopping and starting (booting up, power down); once on, the fan only goes down to 20% speed.Have you heard 100% fans on these cards? It's like a hairblower.... but yeah you prob right, I don't have my card set that high for everyday use. 981 core, 1200mem 1.274 volts, thing never gets above 70c. Thing is, if you are using Vista or Win 7 with aero, if you open up alot of webpages at a time, the card will kick into full speed, and the temps will spike up, thus making your fan spike. Gets annoying after a while. And I think it prob decreases the life of the fan too by shutting on and off constantly when in 2d mode. I just set it to 35% ofr everything below 50c, above 50c fan set at 65%. Hear alot less on and off sound coming fro fan.
Not obtuse at all. I am using Win explorer 8 with windows 7 32 bit. Let me clarify the problem, or rather more of an annoyance than problem. The 5850 idles at 157 mhz core. Lets say you overclock to 1000 core. And lets say this require 1.25 volts. The idle voltage is .9 I believe. Now lets say you are using a fan profile that, lets say, turns the fan on 50% when you hit 40C, and under 40C you have the fan at 20%. Well when you surf and aero is on, your card will go on and off into 3d mode/ 2d mode. ANd thus core is switching from 157mhz to 1000mhz. This can cause temps to go from 37C idle (my idle temp) to 50C for a brief moment, thus the fan swithes from 20% to 50% then back to 20% a few seconds later . Well the fan going from 20% to 50% is pretty noticable. And this revving up revving dwon of the fan constantly is sort of annoying. I think you just have to try different fan profiles and find a nice fan curve. Thans all I'm sayingWhat browser are you using? Does it support tabs? Not trying to be deliberately obtuse, I've just never heard of this phenomenon before. I wouldn't think that this would happen under normal operating circumstances. How many windows are you opening at a time when this occurs?
I'd rather have a HD5870 but it cost more than I'm willing to pay for a single video card.
It was stable at 1 GHZ with Furmark. This is from some Furmark stability testing I did with it at 1GHz core. Well over an hour running (look at seconds ran).
For the most part with my voltae settings it peaked right at 52 degrees C.
It hit 57 because when I started the testing the voltage was higher and I tweaked down the voltage a little to find a sweet spot.
Is there a certain method to the 9.11 Beta4 installation? I was reading on guru3d and they were installing all kinds of stuff and also saying you have to keep the old CCC in tact? I keep hearing good things about this driver.. I want to give it a shot.
By the way Sonda, be careful with driver cleaner, it can screw up VIsta/above from what I hear by removing actual system files... under those OS's there's no need for that sort of thing anymore.
I'm running Windows 7 64 bit RC. No problems.
Currently top of the list on the clock speeds for Vantage at HWbot.
Clocks 1075/1300
http://hwbot.org/result.do?resultId=912242
Vantage score is P18,289 which puts me in 6th place single HD5850 at the HWbot rankings right now.
I am pretty sure I am not the only one who has noticed you can push your clock way higher for 3dmark and end up not stable in games. Yes it can still be fun trying to hit these numbers but in the end most of us clock them back down for daily use.
Being a 5850 owner, I'm probably biased. But I think an overclocked 5850 can easily equal a stock 5870. I do not own a 5870 and can't tell you from a head to head comparison. But using the various reviews around the net, I notice that the 5850 stock gets like 13000 gpu scores in vantage, give or take 500 points, and the 5870 gets around 16000, give or take 500 points. This Gpu number seems realiable across systems regardless of processor or mem config.I actually posted a separate thread about this, but I thought I'd drop a question in here since this one's real active. I recently ordered my Diamond 5850 and heard good things about these cards OCing in general. However there are many individuals on various forums who say that the card OC'ed will not match the 5870, without backing up these claims. However, here are some benchies:
http://www.firingsquad.com/hardware/ati_radeon_hd_5850_performance_preview/page19.asp
http://www.overclockersclub.com/reviews/sapphire_hd5850/8.htm
http://www.overclockersclub.com/reviews/sapphire_hd5850/11.htm
So my question is, to anyone who happens to have some more links or thread related to this, is it true that a 5850 OC'ed to or a little over 5870 speeds will be almost equal in performance to a stock 5870, if not surpass it? These reviews seem to point in that direction.
True....Yeah, but then you could overclock the 5870 and beat that still . The headroom isn't as great but it's still plenty.
Thanks a bunch for your responses SirCumsized. That's precisely the kind of info I was looking for, a first hand experience. I'm not too concerned about how far the 5870 OC's (which from what I read is not too impressive with it comes to OCing), so long as there's the possibility that I can reach/beat it's stock speeds if I OC this beast .
So rather than study for my upcoming exam, I did some extensive testing on overclocking the 5870 last night (because I have priorities like that ). Basically, how far you can overclock this card stably is almost entirely dependent on temperature. I think the water cooling crowd is going to have a ball with these cards. Voltage has a much smaller effect, and really should be used at a minimum. I ended up using voltage to either A) push a clock higher after I had tried all other options (cooling, lowering memory, etc.) or B) stabilize a clock setting at a higher temperature (due to using lower fan speeds). For example, if I keep temps under ~77C using 45% fan, 950MHz is perfectly stable ~1.2V. To stabilize it at 85-88C (where the stock Auto fan profile keeps the card), I need 1.262V. I can run 1000MHz perfectly stable at only 1.275V if temps are kept below ~67C, which requires ~80% fan (damn, I know). I can also run 940MHz at 1.212V stable with only 33% fan and the card stays between 85-87C.
Note, I'm also running the ASUS BIOS now, which, maybe it's all in my mind, helped the card run cooler. It also really unlocked my RAM. I actual could run 1400MHz on the RAM without it crashing. However, it's obvious that error correction was kicking in - literally, games would freeze for a second or two as data was being sent over and over. Note that when you're clocking you RAM, make sure the card is hot before you start raising the clocks. The RAM is much more stable at colder temperatures.
I think my temperatures might be higher than most due to my smaller case. However, I'm really liking 940MHz/1300MHz @ 1.212V right now, and I'm considering that as my 24/7 setting since it's so quiet (33% fan ). If you want any hard data/curve relationships from my testing, let me know. The other thing I want to work on is the cooling for the card. Three things I'm considering now are yanking off the backplate (looks like like it just traps heat in there), redoing the thermal paste on the core, and yanking off the backplate of the card. The last one may not happen as it seems they (XFX or AMD) gimped one of the screws so you can't pull of the back plate without cutting it. I'll see if I can get a tool from my Dad's workshop at home to re-tap the thread so I can extract it safely.
Got a Q for you Mr Sonda...Do you actually play any games? Any at all?
Please post screenshots of 5 different "games" that are not made by Futuremark. If they have an ingame benchmark, that's even better, and let's compare scores. If not, then shut the fuck up. A "game" constitutes, as quoted by WikipediaYes I do. I also have fun tuning my system for performance and doing benchmarks. It's all related to me.
I had alot of fun with the HD5850. I was able to rank the #1 spot for top single GPU system over at Overclock.net with my DFI S775 DFI P45 JR machine. That was fun.
I'm still on the top spot but I think the list needs to be updated. Still impressive to see a S775 system with single HD5850 GPU out performing so many newer systems.
http://spreadsheets.google.com/pub?key=p8z070CFH3nqrHLNAe6VpRQ&w=100&h=615&gid=3&single=true
A video game is an electronic game that involves interaction with a user interface to generate visual feedback on a video device.
Didn't you make a numerous posts stating that 2xHD5770 was faster than a single 5850? So numerous to the point that the Moderators temporarily banned you?As quoted by you http://www.hardforum.com/showthread.php?p=1034830930#post1034830930 It seems to me it's a pretty easy challenge for you. I got one gpu, you have two. You got a quad core cpu, I have a lowly dual core cpu. So what's the problem? It's easy...you're a pussy. Anyway, I'm going to bed, and I hope I wake up tommorrow seeing some screenies from you.I know what a "game" is. I also know what a benchmark is.
The HD5850 I had is gone and I have moved on to Xfire HD5700s. So I will not be able to participate in your invitation.
Sorry.
Didn't you make a numerous posts stating that 2xHD5770 was faster than a single 5850? So numerous to the point that the Moderators temporarily banned you? It seems to me it's a pretty easy challenge for you. I got one gpu, you have two. You got a quad core cpu, I have a lowly dual core cpu. So what's the problem? It's easy...you're a pussy. Anyway, I'm going to bed, and I hope I wake up tommorrow seeing some screenies from you.
