my only problems are with the 5970's. overheating, artifacting, grey/green screen, rattling fan, etc. i'm in the middle of an evga x58 4-way sli build specifically so i can separate the two cards farther apart. 5870's, 5770's, and single 5850 running like champs.
Had some issues initially (grey screen crashes) and thought it was due to OC problem, but after a driver re-install everything has worked fine. I've gone though 9.11 and now 9.12's with no problems.
Asus 5870
One of my DVI ports will display the bios splash screen but won't display the screen when Windows is doing it's swirly intro thing and then comes back on when the log in screen is up. The other DVI port will display the whole boot process. *shrug* Maybe an eyefinity thing?
Sapphire 5870, had since launch.
Running at 900/1300 since the beginning.
When I was satisfied that my card worked without a hitch I yanked off the stock cooler and attached my water block. Smooth as silk...
Sapphire 5850 since launch with no issues except 1 with eyefinity on Windows 7 64bit using 9.11 driver. I put on the 9.12 driver last night and now when I have eyefinity enabled the computer hangs when shutting down. Gonna try uninstalling and running driver cleaner to see if it fixes that issue.
2x HIS Radeon HD 5870's here, both running smoothly. In fact, since I'm running them on the EVGA P55 SLI, they're literally stacked on top of each other with little room between them. Manually running the one with restricted air flow at higher fan speed to compensate.
The only issues I've had are directly attributable to driver immaturity, no show stoppers.
I did have a Diamond Radeon HD 5870 go belly up on me in less then a week of ownership though.
asus 5870 no issue other then a couple of lock up when I pushed it a little high....memory is very touchy past1300...
If your not ocing it and having problems maybe a fresh install of your oS...IDK that usually solves issues
No problems so far with my 5850, stock clocks. Dirt 2 hotfix 9.11s still, work is killing me. Once the break starts I'll load up the 9.12s, but I don't foresee any problems.
Thanks for all the replies! I think this helps us get some idea of just how widespread the problems people are experiencing is. Ive read the statement posted elsewhere "thousands were going through probs with these cards, I dont think its that bad. I have another one coming to go CF and was getting nervous, not so much anymore. My 5870 has yet to show problems so hopefully those with problem cards will get it sorted out. Keep em coming!
My 5970 on it's own is rock solid. I've had a couple issues with the trifire setup although nothing terrible, but i'll accept that for now being that it's probably a less common/tested setup.
XFX 5870 from tiger direct order 12/18
cat 9.12 -not the hotfix
Stock BIOS
Win7 x64
only have CCC installed, no afterburner
never OC'd(yet).
unchecked HDMI audio on install.
running fan at 20% or 50% with hotkeys
Ran borderlands for 30min, then TF2 for 20min. No crashes so far.
GPU temp hovered around 60 with 50% fan with folding@home running.
Had to leave for work. It's sitting at home folding for now.
So far so good.
I did notice Unwinder mentioned on guru3d that AMD screwed something up for afterburner with 9.12s, but he wasn't going to look at it 'til after New Years.
I think ATI is being honest when they say it's a windows 7 problem(in regards to crashes). I'm dual booting Win7/xp and have never had a crash in XP, but 7 gets the grey screen/stripes.
2nd that... I cringe at what an overclock would do to my HX750 with the OC'ed i7 and a pair of 5850. I'm only going to overclock the GPUs when they get bogged down, which isn't really happening yet.
Win 7 x64 Ultimate
Asus 5870 with ATI Bios update
No OC
Running Eyefinity on 3 x 22" LCD 1920 x 1080 thus 5760 x 1080.
No Problems.
Phenom II 955 @ 3.7ghz
9.12 drivers
Specs:
Gigabyte P55-UD3R - F4 BIOS
i5 750 OC'd to 3.42Ghz
Coolermaster dual fan heatsink - N520
cores never get above 41C
Win 7 64bit
XFX HD 5770
Kingston 8GB (Hyper X) @ 1800Mhz (KHX1800C8D3k2/4G)
Dual Monitors:
1.) 1900 x 1200
2.) 1200 x 1600 (portrait)
After about 1 - 2 hours of use, the mouse pointer gets corrupted as I move it from the 2nd screen to the 1st. Cursor always looks fine on the 2nd screen even if corrupted (bunch of dots) on screen 1. If I run windows magnifier and minimize it, it fixes the cursor but has to stay running. Everything seemed fine when I first put the system together. Games run fine, but annoying cursor ruins everything. Switched connection from VGA( DVI with convertor) to the HDMI on 2nd screen, same problem. Screen 1 is on DVI 1. I have gone entire days without it happening.
It didn't solve the problem. My cursor never gets big, I never had that problem. It's just cursor corruption and only when transitioning from the 2nd monitor to the 1st and not all the time.
Just got a new rig:
i7 920 @ 3.8
sapphire 5870 stock
win7 pro 64 bit oem
9.12 drivers (haven't applied the hotfix yet)
no issues yet. Though I'm still waiting to try my first couple of games - crysis & dragon age. I'll report back if I run into any issues.
