I seem to be having a problem when trying to use a 64-bit OS. I found the problem back when Microsoft released the Beta of Windows 7 to the public, and I downloaded it and ran into a bunch of problems when installing.
What happened when I installed it, was that first off, it took forever to install. I'm talking multiple hours, when installation on a friend's laptop (using the same DVD) installed very quickly.
Once I finally got it installed the OS was unusable. Everything was extremely slow and unresponsive. Even the mouse pointer only moved every other second or so. I tried a bunch of stuff, reinstalled, same thing kept happening.
Next, I tried installing Vista 64-bit. Same exact thing occurred. After that happened, I went and installed the 32-bit of Windows 7, and it worked perfectly.
Does anyone know why this would be happening? The only thing that 64-bit is dependent on is the CPU, correct? Unfortunately, I don't have another CPU to try in my PC to troubleshoot. Basically, I'm just wondering if it's possible for a CPU to have some sort of problem where 32-bit would work fine, but 64-bit would have problems. Specs are in my signature.
Thanks in advance for any help!
