jesus, how do you guys keep your cards so cold?tailhook said:Pny 6800 Stock cooling
16/6
Ambient 32c
Core 48c Idle
Core O/C 364.4
Mem O/C 789.8
Core temp under load mid 50's C
i dont have a case, imrunning all the parts on my desk with a fan blowing on em. not exatcly safe but the best airflow around.tailhook said:jesus, how do you guys keep your cards so cold?
The case helps a lot I have Antec SX1045BII which offers good cooling. The way the fans are set up in this case I installed 1 of the front case fans which brings in the air( intake ) across the video card the 2 other case fans the case came with in the rear of the case along with the power supply exhaust it out very well I'm happy with this setup I had this same setup in another case and all the temps were 12c across the board higher.. Plus the cpu cooler helped a little the Zalman 7000c blowing air around the motherboard..
Good Luck
J
Jonboi89 said:i dont have a case, imrunning all the parts on my desk with a fan blowing on em. not exatcly safe but the best airflow around.
*cough* watercooling *cough*cornelious0_0 said:Not exactly best airflow around.....but nice ambient temps on your cards and hard drives for sure......
I've had caseless setups....but right now I've pretty much got an open case......everything's assembled, but right now my side panel is off, and I'm getting an "open" mesh installed in a hole in the side that leaves about 1.25" on each side of actuall panel left.
With room temps a bit higher right now with heat turned up during winter I still have a case temps of 24C, and my Maxtor in front of the two intakes in my case runs at a nice 21C....can't complain.
Warrior said:*cough* watercooling *cough*
saturnine2 said:BFG 6800OC, NV silencer.
Room temp: 24C (76F) Damn this hot NC weather!!! 80F in January, WTF???
Idle: 48C
Load: 55C
ikellensbro said:Forget about what I said before, I disbaled the pipes after all the artifacting in Farcry & even 3DMark 03
Trying manual OCing with Rivatuner testing disabled, cause it wouldnt say evrything at stock was stable
DaRkF0g said:BFG 6800 Ultra OC @436/1.16
Idle core: 48 C
Load core: ~67 C
Great Card, I could probably OC it further if I wanted to.
MrFace said:I just picked up an eVGA 6800nu and unlocked the pipes and oced to 400/8000.
My 3dMark03 score was less than 6000
Gk22CoE said:
JVC said:evga e-geforce 6800 ultra
cst d: 115c - gpu ct 63c - at: 49c, are these the numbers you ask?
Pugger said:cst d: 155c.....
Wtf is that... and why so hot?!
Pugger said:*phew* at least the n00bie (me) dont look stupid
TheLonelySwedish said:BFG 6800 OC 12x6 w/stock cooling
41 C idle 49 load 15 C ambient.....wait till I turn my heat off completely. Winter rocks.
JVC said:other topic
Sp4nk said:XFX 6800GT 256MB
Idle: 50°C Load: 60°C
Stock cooler, but I've got a PCI slot fan two slots down.
cornelious0_0 said:Same thing I did with mine, but with my stock GT cooler I cut off a section of that graphic over the heatsink itself so that the HSF on the card worked as normal, but the CPU heatsink was exposed to recieve even more direct airflow from the fancard.
ScHpAnKy said:those slot coolers worked?!
BloodRayne said:6800Ultra running 440/1.1 at temperatures:
48C Idle
66C RTHDRIBL
64C After a few hours of CS:S
rocky928 said:75C in rthdribl (I have a pile of AS5 on the core and I have reinstalled it 3 times)
47-50C idle
