Ok, it's been about exactly 1.5 years since I've had this monitor. I'm very sad to report, it's now officially DEAD. About two weeks ago, I started having a strange problem where I would turn the monitor on, and for about a minute or two it would show strange striping patterns, and flicker until it finally would show the signal. After it was done flickering, it was fine. Well it took increasingly longer to turn it on until I had to hard-switch the power off on the back to "reset" it. Well now it won't even turn on at all, don't know why. My guess is the electronics that go to the actual panel aren't of good quality, and thus what was causing the "no-signal" problem that some people have been experiencing.
The effect looks somewhat like this:
Luckily though, looking at the papers that came with the monitor, it comes with a 3-year warranty so I can send it in to be repaired. I've been looking on some websites, and it looks like for some reason the AL2423W isn't listed anymore... even on Acer's website.
revenant,
You describe the exact same problem that I had.
I suspect that your monitor will soon die completely.
[snip]
-Wozzy
My AL2423W is dying.. when I turn it on the screen is all scrambled and noisy and eventually it cleans / clears up.. but it's taking longer and longer to clear up.. once it's on though, it works fine.. strange. anyways... I have used the hell out of this thing over the last 4 or so years.. I guess it might be time for a new one though.
Hey krotch, what did you do with your Acer monitor then? If you still have it, let me know.
I just got the monitor back from repairs and its working perfectly now.
According to the service-report they did some repairs on the monitors powersupply.
Oh, and the repair was covered by the warranty.
