Phantom_2k5
- Jan 27, 2011
Maaaaaaaaaaaan, well this sucks, my setup works perfectly @ 4.6ghz and I dont have the patience or the time to even think of any RMA return torture
The Sabertooth series has a fiver year warranty but the rest of our current and recent board series has a 3-year warranty. Where did you get the one-year warranty information from on your board.
If they're replacing the chip on your motherboard, it's not a refurb, it's a repaired motherboard Still, the option to repair your motherboard instead of issuing you a new motherboard is normally stated in the warranty terms. Even though it's an extraordinary situation, Asus would still be well within their rights to simply repair your motherboard.
I'm curious to see how they're going to approach the RMA process, since SMD rework isn't exactly quick, easy, or cheap.
I was going to order my Sandy Build today until I saw this so at this moment its on Hold. I will NOT gamble my money at this point.
Buy a new board in 2-3 years you say? Sure! Send me the money for it and for new memory, graphics card.... I know some people are--but I'm not rich. So, yeah, it's a big deal to me. I'd never have bought it if I'd known it was broken by design. Kept my P3B-F from 1999-2010 and used a 2003-era K7S5A-Pro from 2010-2011. So yeah--it's a big deal. Ideally I'd like to upgrade at least every 5 years if I can--and that's a big if 'cuz money's not exactly running out of the tap. :/Why does everybody on the internet act like sandy bridge motherboards are completely broken just because the old SATA-II ports will maybe break in 2-3 years for 5% of the users ? How many of them will actually keep their board that long and still rely on the old ports to this day ? All the panic about this problem is ridiculous. Our future HDD/SSD's will be SATA-III most likely anyway and i rather enjoy my Sandy Bridge than going through all the RMA hassle just for this and ending up with some refurbished board.
AQ OC I have exactly the same PC as you. Whenever I plug my U3S6 card into the bottom PCI-E slot on my P8P67 Pro it causes my PC to no post. Please try your U3S^ and let me know if it has the same issue.
Care to post anything new instead of the same generic response in all Sandy bridge threads regarding this issue?this is a mess.
I now have the Asus u3s6 card installed in the bottom PCI-E slot on my P8P67 Pro.
It posted fine on the first boot, but after Windows loaded (Win764), it then just rebooted. Upon the reboot, it recognized the u3s6 and installed drivers for both the nec usb 3 and the Marvell sata controller.
IIRC, I have the mobo Marvell controller turned off in the UEFI, but I had installed the drivers in Windows prior to disabling it. Also, I have this same card installed on the p35 mobo with this same version of Win764 installed. I didn't do a fresh install.
I have an HD connected to the usb 3 port on the card. I'm going to do some testing to see if it really works. Maybe I will test one of the sata ports too.
Let me know if you guys have any questions...not sure if I know why you guys are having troubles, but I will try to help if I can.
None one would have bought it knowing it was broken...and it's not by design that its broken...and it's not necessarily broken. It's flawed....meaning there is a potential for performance degradation over time.
This entire thing is out of hand on the forums.
The 5% figure is for every motherboard that has been sold, and is heavily biased by the fact that it is counting on the vast majority of people hardly touching the affected SATA ports.None one would have bought it knowing it was broken...and it's not by design that its broken...and it's not necessarily broken. It's flawed....meaning there is a potential for performance degradation over time.
If you're a heavy user of those ports then the chances of having an issue sky rocket.
Falling into this category I'm rather concerned and until the effects of the issues are clarified have limited what I'm doing to not put load on those ports.
If I could get away with the 2xIntel 6Gb/s and the 2 Marvell ports I wouldn't care, but I also use 3 of the 4 SATA II ports.
So don't bother rma'ing it. No way I'm screwing with RMA even if a port or two goes bad over the next couple of years. I've just got my dvd drive and my bulk storage/media server drive left on the 3gbs ports now. If one of those ports degrades or dies it'll be pretty obvious, so it's just a matter of switching to another port. If they all died I'd just move that non performance critical stuff to a pcie or pci based sata card, even an old pci based sata1 card I've got in the junk box would be fine.There's always the 2 esata ports from the jmicron controller I could turn on and use if needed. If I could still get another 2600K/P8P67 pro combo I'd probably buy it tomorrow to upgrade my second pc.
You won't be so cavalier when you lose your entire hdd.
So from what I understand when the new motherboards come out, I will be able to just send in my P67 Pro board to Asus and they will replace it with the new revised board?
It's in the Policy and if you call them up they will indicate the same. You will always receive a refurb back if repair is not a option for RMAs.Please.....how do you know this?
The chipset problem is not supposed to result in data loss...only loss of performance.
bmg hit the nail right on the head, the potential issue is actually pretty minor and the only real mess is the public response to this issue.
Or purchasing an SATA II adapter as a temporary fix ( assuming you have a free slot ).Then in your case using the four 6G ports is not a practical solution and your problem will only be remedied by you dismantling your system, packing up the motherboard, driving to your local carrier and sending back your motherboard now for a refund or as a RMA in the next few weeks or months.
I agree this is really getting out of hand. Many people don't even take time to read the technical information correctly. Here are some facts.None one would have bought it knowing it was broken...and it's not by design that its broken...and it's not necessarily broken. It's flawed....meaning there is a potential for performance degradation over time.
For the millionth time link please.- The data on the HDD will not be lost
- The manifestation of the problem could be by a loss of performance (hard to detect), but more likely your HDD will disappear from your configuration and coming back.
