Got a before pic? Curious to see a before and after view.
I can't find that on Newegg. Can you post a link to where I could get this for $50?the $50 Rocketfish (lian-li) tower is a WAY better deal.
It's only available in-store at Best Buy:
http://www.hardforum.com/showthread.php?t=1277427
(ignore the $72 pricing, it's $47 or so)
Thats not true, it depends on the store what the price will be. Its a clearance price. Those vary by store. Also, they don't have to do a price match for you since it is a clearance item.
Pics of inside?
Pics of inside?
Thanks for the links.
It all depends on what you are looking for.the $50 Rocketfish (lian-li) tower is a WAY better deal.
Here ya go
Pull straight up and filter pops out
http://img507.imageshack.us/img507/5186/screenwb0.jpg
Bend tabs up and straight so they fit thru slots
http://img507.imageshack.us/img507/2869/tabsjf2.jpg
Inside with spare parts in the case to test
http://img507.imageshack.us/img507/1821/insidedi4.jpg
Power Supply
http://img160.imageshack.us/img160/5450/psupq6.jpg
Both that case and this one are clearance items that you have to be LUCKY to find at a local BB. The Rocketfish also varies alot more in clearance price. To find one at BB is lucky, to get it for $50 is even more lucky.
After buying a PSU the Rocketfish is gonna run you a minimum of $100.
Yeah it looks cooler. Yeah its easier to work in.
I bet my current rig would perform just the same with $70 taped to the front of it as it would in the Rocketfish w/ a fancy PSU.
You should really paint them teal tabs there pretty fugly lol other than that it looks good.
I would personally replace the psu tho i woulnt really trust that one.
These were all ordered online, free ship, no gas, no searching, enough to build 3 cheap gamers for $10+ the price of an empty metal shell. Woohoo. Comparison to the Rocketfish easter egg hunt deal makes no sense. Aren't you in the wrong thread? Here let me help you....link and link2the $50 Rocketfish (lian-li) tower is a WAY better deal.
Lucky? I doubt it. There seem to be plenty floating around.
buying a PSU...why? Most people here have a psu they would be moving into it. The psu argument is bunk.
yes..it looks cooler and is nicer to work with, thats the point.
again: $50 for something nice or $20 for crap.
I'll take something nice.
Couldnt put it better my self. I have 2 of these cases, they will both likely end up with friends and/or as side systems.The teal crap is only inside and this thing has no window. Some of it is rubber and paint hates rubber. Besides, these are going to someone else for a cheap LAN gaming setup where cost was a concern. He is full aware the risk of the power supply. I had fun with this particular case mod and may keep one with my own PSU and gaming setup.
The case is far from crap for $20, maybe not so worthy at full BB retail tho.
nice work Staypuft.. mine still in the box waiting for some more funds to complete it..
i wouldnt use the dynex psu anyway. rocketfish ftw
Does the CPU fan stay on as well? Could be your ACPI settings in BIOS / Windows.
