I'm thinking I need to take my brothers advice with the washers. Too odd that it's fixed his issues several times and again with a new build yesterday for his media center.
Batter is testing at 3.7 - 3.8v.
No good. Same results. Just reboots. Followed your instructions at post # 282 to the letter.
This started right after I moved the case into the cubbyhole (dedicated space for case) on the desk.
Okay, what if this thing is shorting on a screw and moving it cause the case to twist slightly?
What is this Batter you speak of?
Wait so can you get into the BIOs now or still can't? Try booting with just one stick of RAM.
Um....move it back?
I find it interesting that this problem came up again after I physically moved the case a tiny distance.
Setup everything outside of the case, with the mobo on top of its cardboard box. Plug in only the essentials:
- PSU (namely: main 20/24-pin ATX connector and 4-pin ATX12V P4 CPU Connector (OR 8-pin EPS))
- CPU w/ HSF (don't forget to plug in the fan)
- Single stick of ram
- Videocard if there is no onboard video (and PCI-E power, if needed)
- Monitor
- Keyboard
- System speaker/buzzer (if no onboard one is present)
* Use a screwdriver if your board doesnt have an onboard power switch. Jump (connect) the two power switch leads to turn the power on (hold connected for a few seconds).
What did we know before again?... But, we knew the before. ...
The G.Skills are 2.0-2.1v, but I've had far less problems with them than OCZ sticks recently.Oh....you can get high speed RAM with those voltages?
But, we knew the before. So am I dealing with two things here? Or can this kind of psychotic behavior happen with RAM?
It should not matter which bank you use. Just stick it into any slot and run memtest.Best way is to use Bank 0 correct, for testing RAM? Closest to CPU.
Well, to find that out for sure, run memtest on a single stick in that bank and see if you get errors, and if you do, try the same stick in a different bank and run memtest again. If you don't get errors, then the bank may be faulty. If you still get errors, chances are it's the RAM.
I've always heard no upc means rma to manufacturer. If they let you return it and order a new board, you could just file for the rebate again. All I'm saying is be careful. Found this on the Newegg RMA policy:
RMA processing time may vary depending on the product and reason for the return but generally processing time is 2-5 business days once the RMA is received and meet all following criteria:
1. Return with RMA number clearly identified in shipping label or on package.
2. Return with all original equipment, components, manuals, cables, documents, packaging.
3. UPC code along with retail package.
4. No physical damage caused by customer or by carrier.
5. Item is NOT out of warranty when it is received.
I'd try new RAM first, before RMA'ing the board. I've had bad RAM cause me to return a non-defective motherboard, and they just sent the same mobo back to me (same test you did led me to such a conclusion).
Are you serious?
After all that testing and with these results it could still only be the RAM? How is that possible? If it tests fine in one bank and both sticks fail in the same different bank.
Just curious here. Don't get me wrong.
