Countdown to 1000 new borgs/addition
Upgraded my wife's Venice to an E4300 @ 3 GHz running two instances of the standard client. So, +1 and a lot more speed.
958
three e6700's running 3 Smp clients
960
Did you added three? is so dot an extra off two from the most recent count.
EDIT: I've done it for him, he added three but only counted one.
CURRENT COUNT:
956
Delete - P4 2.0Ghz - Console - Linux (Father Needed Basic Computer)
Add - E2140 Linux SMP
I am maxed at this point. Unless someone wants to just give me systems. Even then I have no more space left!
955
I suppose I should add:
+1 Q6600 (2 clients)
-1 XP 2100
Net result is one more folding client, and much faster unit turn arounds to boot
954?
:D
Added an E2140 @ 3.2 (Running SMP) and a 754 Venice 3000+ @ 2.5 tonight.
947
I'm guessing that'll be two clients in itself, so that'll be
948
Reminder: Don't count the number of cores you have folding, count the clients please.
947
Added a dual Opteron system last Friday. Running one SMP Linux client on it.
Posted in the SMP countdown, but add and upgraded, OC-ed 3600 X2 running SMP.
Also....
A64 3500 being used for Linux dev stuff conveniently back folding thanks to a power supply contribution from EvilAlchemist :D
945
Added a few:)
E6750 2.66 2g ram running two standard clients
Five Celeron 2.4g 512m ram
Eight Celeron 2.8g 512m ram
Fifteen total!!
930​
Add the E2160 in my sig, bout to turn in it's first WU! :cool:
928
Just loaded it on my E6750. My first workunit should be done around 4pm EST.
922
Just added a few boxes and completely switched over my pre-existing boxes to the Console client. Nearly all run the SMP client as well. All I need now is another CPU and mobo for my empty Ultra Microfly.
1x Xeon 3060 (E6600) @ 3.15GHz - Home box
2x PentiumD 3.4GHz
2x T7100 Laptops that weren't doing anything. - Not sure how long I will have these :(
1x Dual-core Dual CPU Xeon 2.8GHz running four virtual clients. - Not sure about the ideal set up for this one. I will probably have to look at loading a 64-bit OS to really take advantage of this machine.
908
Dual Quadcore running 2x SMP Clients [1 client full time, 2nd one turned on every night and while at work]
907
Used to read Maximum PC when it was 'CDROM Today', then 'Boot', and only slightly in the current incarnation. Lost its edge, if you ask me.
905​
edit: [email protected] (16hrs/day) and T7200 (20hrs/day)
Well now your [H]ard :D
One Q6600 at 2.4 GHz for like 16/h a day because I'm going to be fooling around with it. I won't overclock it on stock cooling so I'll order a heatpipe for it and OC it. Hopefully I can get it going 24/h.
904
Since this thread was opened I've added:
2 HP DL360 Gen5 Dual Xeon E5450 (quadcore 3ghz)
1 HP DL380 Gen5 Dual Xeon E5345 (quadcore 2.33ghz)
and I've got 4 more boxes on the way.
901
895
Added my 6 boxen to the horde.
way more than 200ppd however, I hope! :)
and ninja edit: I wish I could read the bottom of a thread before replying
C2Q GO @ 3.6 each (one running 24/7, one running 14 hours per day), PS3
+ these as soon as I get some more OS'S Athlon XP 1800+ Venice Core @ 2.7, AMD Athlon Thunderbird @ 1.5.
892
soon to be 890 ;)
892
soon to be 890 ;)
Run a diskless system and don't waste your money on windows.
two for the price o' one.
888
Dell Dimension 4500
1.8Ghz P4, 512Mb RAM
Folding at 66% usage.....Can I increase it to 100% and expect it to still be useable? (Does it only fold when idle?)
887
Compaq Armada E500:
600Mhz P3, 128MB RAM
Folding 100%, 24/7! >:D
Both've been working since before the new year, and I'll keep 'em going as long as I can.
Dell Dimension 4500
Compaq Armada E500:
The single core client is VERY good at running at low priority, so the computer will be very usable with the client at 100% :)
oh yea and
887
doing a helluva job here guys :D
I borged my work computer today. I just put the regular (not SMP) client on for now. I might change over to the SMP in a few days after I see what that computer is going to be willing to do.
886
I just signed up yesterday and started folding with 8 Single core 2.8ghz to 3.0 Ghz P4's with 512-1024 ram. I've been asked to update this thread and it all makes sence, How did u guys get the numbers in Big Red print? thanks!
885
884
883
882
881
880
879
878
