wait...if they discontinue this model..then what happens to that 3yr warranty? what would they replace it with, if they dont make any more of them?
referbs?
What's up with the Dell production of the 2007WFP? Their site says "call for pricing; 3-5 weeks delivery, ect." Is their any information regarding a continued S-IPS version, or is it history? I know that they are pushing the SP2008WFP bels and whistle model, but they are still listing the 2007WFP Ultrasharp. I'm down to one Dell P992 CRT and have been watching the ebay auctions going wacky on every Rev. model. Many sellers either don't know what they are selling or won't tell you the serials and other info, because "it's guaranteed new; it's packed up and ready to be shipped...and other excuses" I already distrust Dell and am ready to give up and go for an NEC or two. Frustrated Tomcaster69 P.S. Is it still possible to get one in Europe?
Discontinued. That's what happened . Get the NEC because the life of 2007wfp is over.
Hate to break it to you but i'm pretty sure the life of the NEC IPS is over too, going the same TN route as the Dell.
For those who has the Dell 2007FP/WFP, do any of you have eye strain after staring at the screen for hours? I'm looking for a good monitor for reading and gaming, but i've had eye strain problems with most of them. I'm fine with most good quality CRTs, go figure, but i haven't tried any 8bit LCD for extensive periods of time yet.
Thanks in advance.
I was surprised to discover the same thing with my first LCD. The two culprits tend to be Brightness (Most LCDs are too damn bright even when turned down to zero brightness) and for me: Horizontal viewing angle problems, which sort of cause a phony 3d effect which forces my eyes to strain more. Look for LCD's with lower brigthness scores and try them out if you can to see that the brightness control goes quite dimm. Getting the S-IPS version would help with the viewing angle problems.
I've found too that using LCD's in the dark makes the eye strain harsher. I mean, with the newer LCD's too they just keep upping the brightness like the max wasnt good enough quite some time ago.
although i noticed this most when i got my LCD television, and i couldnt stand the eye strain, i'm surprised so many people put up with it and i dont know if they'll ever fix it, or if the newer techs like SED or OLED wont have that issue. It's leading me towards getting a plasma now.
can you tell if it's s-ips without opening the box? thanks.
Can I get rid of this problem if I use a better graphic card which has DVI output?
Thanks in advance!
Guys
I sent a PM a while back to a member here who helped me out in terms of what to look for when trying to get an IPS panel in a used 2007WFP. The guy gave me all the info I need, but he mentioned that the instructions for accessing the service manual to check for RT-803 are given in this thread on pages 72-73. I checked those pages but couldn't find the instructions, and I have to go see one this weekend.
I've never handled one of these so could someone tell me how I go about accessing the service manual screen so that I can check for the RT-803 which should indicate S-IPS?
So far I know that I should look for an L at the end of the serial #, Rev A04, made in Mexico. Any further hints as to how to ensure I'm getting an S-IPS would be appreciated.
Thanks
Nik
2007 FP A03 - Panel Code UW473: S-PVA Samsung LTM201U1: Proof, someone disassembled )
2007 FP A03 - Panel Code HN210: S-IPS LG.Philips LM201U05: Suspected, process of elimination.
If you get an A03 Dell, share your Panel info from the service menu, so we can translate dells codes back into panel info. Especially if you are sure you know what type of panel you have, or even better you have taken it apart to confirm.
NOTE: If you have an older panel, the panel name is not obscured, it will directly tell you which panel you have.
To see the service menu(panel info on top line):
Turn off the monitor.
Hold down "menu" and the "+" while powering up the monitor.
When monitor is fully powered and the input graphic disappears: release "menu" and "+" then press the "-" button
Guys
Thanks
Nik
i got one manufactured in Jan 2008 and it's a S-IPS!!!!! whohooo!!!!
People don't praise S-IPS because it it perfect. It's because TN and PVA/MVA panels are so much worse. With TN/PVA, you can look at the screen "dead on" and still easily notice gamma shift. And I don't think the purple is as bad as gamma shift. It looks more like a diffused reflection.Finally got mine- ends in an 'L', has the purple tint that indicates it's an S-IPS.
My impression: I'm somewhat surprised people have praised S-IPS this much. The purple tint on dark colors shows up at very shallow angles, I have to look at the screen dead on to avoid it.
