True. My complaint is mostly with the very noticable banding though- It's not as bad as the banding in the earlier models, but it's still present enough to significantly degrade image quality across the board, even when it's not easy to pick it out directly. Colors just look off all over the place because of it.
Basically, greys, especially dark greys, don't have anywhere near a smooth progression (most visible with gradients), and are slightly off-color. My laptop, which is a TN panel, has perfectly smooth gradients but they shift with viewing angle and have dithering. Even so, it still manages to look better than the off-color banding I'm seeing here. If I can't fix the banding, and from messing with numerous monitor and graphics card settings, I'm going to have to find something else, this is unacceptable in a monitor that's supposed to be accurate, when I don't see it in any other LCDs of significantly lower quality.
I think I know what you mean. For instance, on my 2007WFP S-IPS, when looking at HF forum main menu, it seems that in the middle the greys look brighter than on the right of the screen. Is this the banding issue you are referring too?
