whrswoldo said:This is with E6300, DS3 mobo, Patriot 2x1GB 667MHZ ram
Wow. Is it the ram, or can call value ram OC high with intel chips?
Jodiuh said:What ram is this? The 4.4.4.12 with Black spreaders? What VDIMM are you running? How bout voltage on the mobo?
provoko said:Wow. Is it the ram, or can call value ram OC high with intel chips?
istymie said:...ntel stock cooler @ 47c I/51c L (fan control off)
Moddest Mouse said:could i get to 3ghz (on the ds3) using this ram: OCZ platinum 800mhz 4-5-4-15 ? its 2*1gigs
scientificTHEgreat said:Just for good fun I have decided to up the Mhz on my 6300 to surpass Kyle!
See ya Kyle
It's only going to go higher
PS no phase cooling allowed!
Dan_D said:Same here. I later moved to the 300A, but I went through three chips before I found one that would run stable at 450MHz believe it or not. For some reason I can easily find processors that won't OC for crap.
Like the Pentium 4 "Northwood" 2.4C I had that couldn't do anything higher than 2.6GHz.
Nitron said:What kind of system memory are you guys doing this on?
schriss said:So, do you need DDR2-800 or 1000 to get high FSB on DS3, because you can't set memory to run slower than FSB?
Is 6300 multiplier unlocked?
chrisf6969 said:Yeah, but "real-world" when you jack up the resolution and AA/AF, all those
chips / mobo combo's you bencmarked (in the Giga review today) are
going to be about the same +- a few fps, so why bother upgrading your rig.
j/k!!
I'm starting to wish I had gotten an e6300.
I'll have new ram in tomorrow, to see if thats
whats holding my e6600 back at 2.75Ghz.
http://www.crowdcontrolusa.com/overclock/shizzy3.html (old pics, but new benchmarks)
BTW, NICE OC, Sifulee!!
j/k!!
kelim said:Guys, I really need help bad.
I've bought a Conroe setup with overclocking first in mind, and I can only get up to 380x7 stable. I've tried giving vcore 1.4, but even then I can't Prime at 400x7 for more than like 15 minutes. I don't know what to do. I don't know how to adjust chipset voltage because I can't find the setting, and I don't know if I even want to because my NB heatsink will burn my finger if I touch it. Thanks in advance.
Demon_of_The_Fall said:Try getting a Zalman / Thermalright / Vantec / Whatever aftermarket northbridge cooler and cool that sucker down.
blurp said:You might want to check your cooling. At 3 GHz I get 55-56 C degrees max with CoreTemp reading with 1.325 volts. This may contribute to limit your OC.
kelim said:How are you guys adjusting MCH volts?
Skrying said:I just ordered a 6300 and the Asrock 775Dual-VSTA (need my AGP!). I'll be using an Arctic Cooling Freezer 7 Pro to cool it and the system will be rounded out by some Geil DDR 400, 6800GS AGP, and a number of IDE drives. I expect I'll have some interesting results. It should be very interesting to see what, if any, OC I can pull out of this setup.
schriss said:DDR400 means 200MHz, so with this RAM it may not be possible to hit high FSB, right?
kelim said:I do hit CTRL+F1 when I enter my BIOS, but I'm not getting any MCH settings at all. I'm using F4E.
Lyquist said:I'm running my E6300 at 2.8GHz 400 x 7. I don't think my Patriot 667 ram will go any higher than 800. I'll buy new ram once the prices come down.
Lyquist
mjd1964 said:Hi everyone, I'm puting together a e6300 system and I was wondering what speed you leave them at for 24/7 use? How much faster is this setup compared to a [email protected]?
