Just FYI, the p-7805u has 2 empty trays for additional internal hard drives, and an internal port for a second wi-fi card -- bluetooth perhaps? Very easy to access!
I went to BestBuy and checked it out.. After a LOOOONNNNGGG wait for help I bought it. As big mike said, it's a piece of cake to do the swap. Peel off a small rubber cover, unscrew one phillips screw and out it comes. It is a SATA drive (contrary to what the Gateway tech emailed me -- he said IDE). The only thing about swapping the drive for a blu-ray is you'd have to use the original beveled faceplate for it to look right.. This also doesn't look too hard, but I didn't get that far into it without the replacement. Newegg has 2 Sony models (BC-5500 & BC-5600) for $309 that appear to be the slot loading type (instead of the sliding tray type). Found them on ebay for about $150. I'll let you know how it goes...
