beyond thatif set to 90 or 100, leafblower loud I suppose.
Once ATITool or somebody else figures out how to get overclocking working, I'd suggest deleting all your profiles in the Profile Manager. That will set CCC back to defaults and allow the program to change settings unhindered.
In my 3870 experience, I think the 3rd party apps would override the XML settings, but I could be wrong. I'd try to keep it clean just in case.
I have 3 profilesOr buy an Asus 4850 and say Thank You!
btw, %40 seems to be the sweet spot in noise/temp ratio for mine.
Has anyone removed the stock HSF, and replaced the original thermal compound/tape with some Artic Silver? That usually help to bring down temps.
I am picking my 4870 up tonight, and was considering doing this first thing.
I would apply this fix only if my Catalyst Control Center WORKED. Displays drivers are working on my 4870, just CCC wont load without errors. (I have .NET and am Administrator)
I must fix becuase I dont want to run my card at 78C IDLE for any longer
I suggest you re-read the OP (or, read for the first time?)Where in the settings in CCC can you control the fan? I only see the overclocking settings.
I've a question about this...
One you set the XML file, and the new driver and/or third-party prog support is released, do you have to go back and reset the XML file? Or would installing the new driver just start everything anew? Or perhaps just have to change it back if using a third-party prog, since that's not the same as installing a new driver, which resets everything?
Figured others might want to know this as well, and I haven't seen it asked yet, and I'm assuming (hopefully) someone will be releasing something that's compatible with the 4800 series to more effectively control the fan speed.
You can't. CCC doesn't have fan control options, which is the purpose of this hack and this thread.
Gotta say, between green and red, I'm growing to appreciate all the extra bells and whistles Forceware drivers have that CCC doesn't. Fan control and game profiles the most.
Actually there are game profiles you can set up easily, under the Profiles button in the CCC . You point it to the .exe you're running, save it and set the settings for it. Then it will activate that profile automatically whenever that .exe is launched.
47%-52% variable fan in BIOS with flash, 100% stable, ~25% performance increase in Crysis over 790/4000 :
great OC.Actually there are game profiles you can set up easily, under the Profiles button in the CCC . You point it to the .exe you're running, save it and set the settings for it. Then it will activate that profile automatically whenever that .exe is launched.
great OC.
You set those clocks via BIOS flash I assume?
I hope they make automatic profile loading, having to manually load this everytime i start my pc is really fucking gay, Im still pleased with my AMD purchase but god damn this is the kinda crap I was expecting to see having moved from Nvidia and I'm already seeing it....grrrr
got to the activate panel of the profile manager and check "desktop shortcut". this should make it better for you, unless you consider one click on an icon is gay, in which case you dont get much stuff done.
Good stuff, wish they could implement fan control in the CCC panel in 8.7 without having to manually edit. Waiting for the acceleros though to really get the ball rolling. Only $25 at directron.
