chinked|out
- Feb 6, 2006
so guys, and gurus.
i know everyone in here is great help. so i decided to post here for some water cooling information, tips, helps, and recommendations.
first off, let's show you my components in my case:
Processor - Intel Core 2 Duo E6300 Conroe 1.86GHz 2M shared L2 Cache LGA 775 Processor
HSF - ZALMAN 9700 LED 110mm 2 Ball CPU Cooler copper
MotherBoard - ASUS P5W DH DELUXE/WIFI-AP LGA 775 Intel 975X ATX Intel Motherboard
Ram - G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Unbuffered Dual Channel Kit System Memory Model F2-6400PHU2-2GBHZ - Retail
Video Card - XFX PVT80GTHF9 GeForce 8800GTS 640MB GDDR3 PCI Express x16 Video Card
PwrSupply - Enermax 620W
Main Harddrive - 250gb
The case i'm thinking about occupying for this job is silverstone black temjin tj07. the only problem here is that i don't know how to mod or never done it before, also i don't want to buy a bunch of modding accessories just to setup watercooling internally. i was inspired to keep this case after seeing Theorie's water cooling setup.
my current case has 3 harddrives occupying one of the 2 hard drive racks on the bottom portion of the case. i'm using a hd rack on the 5.25" drive bays and i have 2 optical drives in the 5.25 drive bays. as far as i know i can get those silverstone drive bays which allows me to mount 3 harddrives using 3 5.25" bays. and if i need mroe space i can just buy single HD racks.
now the problem is having a radiator. i'm thinking about triple rad on the bottom taking out one HD cage or 2 hd cage if necessary. i want to be able to cool, my gpu 8800gts and e6300.
i'm looking to spend less then 280 on water cooling. i was thinking buying from petratechshop since the guy is south of me by like 35miles. also i was looking at his kit with the dtek block for the cpu.
now all i need is recommendations, encouragement and tips.
how hard to setup the wc kit compared to air cooling?
would it really take 10 hrs like couple members on this thread did?
would i really gain temps?
would the case be a lot more silent?
what are the chances of a first timer to mess up and get leaks killing his hardware?
what if i dont' put my gpu onto the loop right away and wait a while until later? would it be hard to add a gpu to a already setup loop?
what happens if you don't do any of the cleaning processes in the beginning before setup? is it really necessary?
how would i go about mounting the rad without drilling holes and keeping it on the bottom section of the case? can i use valcro? would it support the RAD?
current temps are as follows (on air of course)
Full load
idle
how much would i gain when i move to water?
Full load
idle
