I'm using it, it works. Nothing really to say about it .
Those aren't calculations, they're stats pulled from EOC. Go into Edit>Preferences>Web Settings and configure your user info properly, and you should see the numbers reported properly.1) the calculations at the bottom particularly week and total are way out of wack.
You just run the program, add the clients you want to monitor from the Clients menu, and customize the UI to however you like it. It's nothing complicated.I think im a little confused on how to use this client bro.... can you gimme a dummies guide to runing this program, and installing my clients on it so they list and show there current values.... I have my EOC username # in, my Stanford ID and team ID in the user settings, but I cant figure out how to run the actual client..... hah
How do you import the config file from Fahmon? In particular, where is it?
harlam357
Any updates on the Core b4 issue ?
The Vista equivalent would be C:\Users\<username>\AppData\FahMon\config\clientstab.txt.If you're using the latest FahMon v2.3.99.1, it's here on XP:
C:\Documents and Settings\<username>\Application Data\FahMon\config\clientstab.txt
Nice .Thanks to all for the kind words... get ready, v0.4.0 is coming... like in less than 60 minutes.
Oh. Right. Thanks.If you're using the latest FahMon v2.3.99.1, it's here on XP:
New Version: 0.4.2 - Revision 92 - Beta - Download (MSI) Download (Zip)
Need help with HFM? Have a Feature Request? Please Join the Discussions. Post in the HFM Google Group.
http://groups.google.com/group/hfm-net
I just installed it. However its nto reporting the credit for my -bigadv box. under credit it says "NaN"
