I still think I want 8GB of ram Is there a program that can monitor ram usage and show you how much you are using?
I noticed a huge difference going from 2 GB to 4 GB in Vista x64
Taskmanager? I've got a Windows Sidebar gadget that monitors RAM usage. Typically with 8GB it states that 37% of the memory is used while essentially idle. Granted you have to keep in mind that Vista uses idle RAM for superfetch so having 8GB of RAM or more won't make the usage percentage go down a whole lot.
If you go into Task Manager chances are it will show your physical memory as having very little free. I have a Sidebar gadget monitoring CPU and memory usage as well, and although it's currently at 51% usage, Task Manager shows 35MB of free physical memory(it's usually lower actually). Superfetch literally uses all available memory, which is rather nice, so it should scale up to use all the memory in an 8GB system as well.
i have 8gb in vista64 and can't tell a difference if i pull 2 sticks out. with taskmanager up i normaly use less than 4 gigs but i got the extra for futureproofing.
Anyone here use that ReadyBoost feature w/an SD card or USB thumbdrive? I seem to recall Anand doing some testing on it and it didn't really seem to help performance much at first (dunno if Superfetch actually cache'd stuff to it or what)... I wonder what speed thumbdrive/whatever they were using though.
I have 3 GB in one lappy and 4 in the other and I can't tell the difference, but with 1GB on our last lappy (all vista) you can tell the difference.
