What's wrong with S-PVA?
Right now, it's probably between the HP LP2475w and the NEC 2490. In essence, each has its advantages and benefits. I would've gone with the refurbished but I'm always skeptical of refurbished products and I can't risk it with the 90 day warranty.
Yes, the HP does have wide gamut but so do 90% of new monitors. I would basically say that if you have the money to spend, get a new NEC 2409 for $1200. If you don't mind a refurbished product with 90 days of warranty, get the refurbished NEC. If you have a colorimeter/hardware calibrator and you work with photos/sRGB and such, you won't be bothered by the wide gamut all that much so then you can opt for the HP LP2475w. Just my .02.
The refurb Dell 30" comes with a 3 year no questions asked advanced exchange warranty. And most people are receiving units that appear to be new. I received one that wasn't... but it was still an amazing value, and all I needed to do was have them swap it out.
I called Dell, and they said the 3007WFP-HC refurbs have a 90day warranty only.
Also, what is the problem with wide gamut monitors?
Yeah, I'd like to know the answer to this too. Surely they provide better colour accuracy?
maybe I can slap on a new color profile that will correct the wide gamut effect when viewing the web?
Wide gamut, in my honest opinion, is certainly advantageous when doing work with photoshop and other color intensive programs. I often work with photoshop, lightroom 2, and photoshop elements so I wanted the best color accuracy and gamut. On some web pages, I do notice a bit of oversaturation but it is nothing that I can't live with. In games and movies, I actually notice an improvement in blacks, colors, and contrast over my previous Dell 2405FPW (PVA which is also wide gamut, I believe) so overall I'm satisfied with wide gamut.
Snowdog, in most of your posts, it sounds like you are trying to justify the purchase of your 2490. Nothing wrong with that but that is the sense I'm getting from reading most of your posts.
I also correct incorrect assumptions. You get ZERO advantage from working with a wide gamut panel even in photoshop unless you have wide gamut sources. Which most people don't have. Even then advantages are marginal. The main advantage of wide gamut is to marketing departments because the have another value to claim bigger is better. Put it in the bag of marketing lies with Dynamic Contrast and 178 degree viewing angles.
As to the viewing angles, I recall you mentioning that the NEC 2409 has the best viewing angles. I strongly think that most people would not care because they sit directly in front of their monitor, and not above/below it or to the left/right of it.
At the end of the day, the consumer has to make an informed decision. The NEC 24" is an excellent monitor and I can say this without any doubt. However, whether or not it is worth the $1,200 is another question entirely? It certainly has certain disadvantages (older model, input lag, response time) as does every other monitor. I went with the HP because it is a solid all-around monitor with an IPS panel for a reasonable (according to the market) price. If the NEC were new with warranty for that price, I would've had a harder time making my decision.
I think he characterized the NEC polarizing filter as a nice bonus, and it would be. But I agree that it's not vital as long as the unit will be used by a single user and not for collaboration. I know the white glow on my 24" Apple display is only evident if I'm at an angle and diagonal, which is a complete non issue for me. In my case the internal speakers and the web cam/mic are a better bonus than the polarizing filter would be. Now at 30" I think you can make the argument that the corners might glow depending on the single user viewing distance.
Yeah. I read much of the HP thread. Some people are bothered by white glow even at 24" but I haven't used one. But on a 30" IMO they need the polarizer, but even the NEC 30" doesn't have one. Still I love the polarizer on mine. I move around a lot, it is nice to have essentially perfect viewing angles. You probably don't need this, but it sure is nice. Another potential wide gamut downside from the HP thread is a lot of people report text issue and seeing red on edges.
But I was mainly commenting on the Nec vs the Dell 30" that someone else suggested. The cost about the same price new or the same price refurbed. In that case I say go for quality instead of quantity. If you can afford a Dell 30" you can afford the NEC. One is a pain (dell) and the other is a joy. I don't think the HP is nearly as bad as the Dell.
Saw a few Refurb NEC2490WQXi for around $630
$637 (shipping not included) from TechForLess. Refurbished with 90-day warranty.
Has anyone been brave enough to order the refurb'd NEC 2490, and if so how did it work out and what is the policy with dead pixels? Can you only return if it's "defective" which I am curious what that means (> x # of dead pixels)?
I ask because, like so many other folks, I'm trying to decided between the HP 2475 and NEC 2490. I was just about to go with the HP 2475 based on my finances / features and then . . .
PS- Thanks gang for the spirited debate on the two LCDs as I'm sure it's helped more than just me narrow in on the pro's and con's
