sdotcarter
- Jun 23, 2009
I know the Core 2's arent hot anymore but im looking to squeeze some life out of mine for a possable graphics card upgrade.
Gigabyte EP45 UD3P
Running at 3.33 Stable, looking to get into the 3.75-4.0 range.
Temps currently are
32-34* C on both cores Topped at ~58 under load. Passes Intelburntest 10 cycles.
Memory is G.Skill ddr2 800, the blue ones.
What im thinking is if i can get it stable in the 3.75 range I'd like to get a 5850, then a q9550 after thanksgiving next time I can hit mc.
Hopefully some of you remember this chip and can help lol.
Gigabyte EP45 UD3P
Original Settings robbed from Tweaktown Forums
Robust Graphics Booster.........................[ FAST ]
CPU Clock Ratio.................................[ 12x ]
Fine CPU Clock Ratio............................[ + .0.0 ]
CPU Frequency............................[ 280 x 12.0 ] 3.36Ghz
******Clock Chip Control******
CPU Host Clock Control..........................[ Enabled ]
CPU Host Frequency (Mhz)........................[ 280 ]
PCI Express Frequency (Mhz).....................[ 100 ]
C.I.A 2 [Disabled]
******Advanced Clock Control******
CPU Clock Drive..........................[800mV]
PCI Express Clock Drive................[900mV]
CPU Clock Skew..........................[0ps]
MCH Clock Skew..........................[0ps]
******DRAM Performance Control******
Performance Enhance.............................[ Standard ]
Extreme memory profile (XMP)..................[ disable ]
MCH Frequency Latch.........................[ AUTO ]
System Memory Multipler.........................[ 3.00A ]
Memory Frequency 1066............................[ 840 ]
DRAM Timing Selectable..........................[ AUTO ]
CAS Latency Time................................[ 5 ]
tRCD............................................[ 5 ]
tRP.............................................[ 5 ]
tRAS............................................[ 15 ]
******Motherboard Voltage Control******
Load-Line Calibration...........................[ Disable ]
CPU Vcore [ 1.1625 ]...................[ 1.375v ]
CPU Termination [ 1.20 ]...................[ 1.26 ]
CPU PLL [ 1.50 ]...................[ 1.57 ]
CPU Reference [ 0.760 ]...................[ AUTO ]
MCH Core [ 1.100 ]...................[ 1.16v ]
MCH Reference [ 0.760 ]...................[ AUTO ]
MCH/DRAM Reference [ 0.900 ]...................[ AUTO ]
ICH I/O [ 1.500 ]...................[ 1.57v ]
ICH Core [ 1.100 ]...................[ 1.20 ]
DRAM Voltage [ 1.800v]...................[2.00v]
DRAM Termination [0.900v]...................[Auto]
Channel A Reference [0.900v]................[Auto]
Channel B Reference [0.900v]................[Auto]
Temps currently are
