Hm, $59.95 from Adorama Camera via Amazon, weird. Then again I live in Delaware. sup no taxes.
Anyways (don't want to derail playing price-tag ), unfortunately I haven't been able to get a Spyder2 or a Eye-One through work because a money flux occurred so I had to hold off on upgrading my graphics monitor and the tool to calibrate it.
I guess you can call me sneaky but then again I make graphics for them at home too.
I want my dark-dark greys to appear a bit more but I cannot bother to try and go through steps to fix it... ...maybe soon...
I had the same problem when I tried to monkey around with it a couple days ago...I thought I was simply not doing something right and with no guide/instructions I couldn't figure out exactly what that was.
I agree that there is little or no support. Colorvisions support page is useless.I bought this 3 days ago and it sits in its box doing nothing.I was under the impression that this would calibrate my lcd and load a profile.And yes the instructions are confusing and of very little help.After installing the drivers I rebooted and on reboot Spyder2 tells me no color profiles loaded .At this point I havent even plugged the usb sensor in.So I plug it in and xp recogonizes the usb sensor.I start the program and get a error....I click next after clicking ok and get a new page with a new error that the meter is not sensing.I click ok and get to where you put the meter on the screen and go through the color process.At the end it says color profile has been loaded .But there is no change.I reboot...Colorvision tells me color profile loaded but there is no change????? My desktop is still the same no changes in color or anything.I look in my color profiles and find a spyder2 profile ....so now what ???am I supposed to do something with it ???? I know what I would like to do with it and this piece of junk Spyder2....cant return it as from newegg and no return on this...Sure am not going to make a international call for tech support which looks to also be useless.I have also loaded the spyder2 profile in color management and made it defualt...no change.I did a complete reinstall of xp all latest greatest drivers for my Nvidia 9700 gt sli....no change...bios uptodate...all xp updates ...no change.
Anyone got any ideas ?????????
Im about to pick up the Spyder2Express. Will it show a noticable improvement in games after calibration? Someone posted some pictures of CS:S before and after using the Pantone Huey and the difference was huge. (I think it was in the x22wg sceptre thread)
Thanks for the confirmationI noticed some colors in BF2142 that I hadn't seen before I calibrated with the Spyder2Express, It's definitely worth it as BF2142 is a dully colored game anyways. If the Future is that miserable looking, I'm glad I don't have to live that long.
Ok I just got my spyder tonight and calibrated my screen. The before/after difference was HUGE but for some reason whenever I load my games windows or my ATI drivers seem to use their own color profile, any way to disable this?
Hmmm Im not using CCC, im using ATI Tray tools, The only game that seems to NOT use the windows profile is CS:S. Titan Quest and BF2142 both use it...strange.
Is it worth buying a Spyder2 Express even if I'm not buying it for comparison of monitor color to print color? I'm not a graphics person but I do want colour accuracy on my monitor in the sense that, for example, on sites I want to see the colours as they're meant to be seen. Like say on Newegg the orange bars at the top seem overly bright (sorta neon-like) to me. So is it overkill to buy a S2 Express when I'm not doing any sort of print work? I do game though but from rawashdeh's post above I'm not so sure I should buy it now..
Well my colorprofile works just fine in most games and i can see the difference as soon as I load them, just one game I have right now (CS:S) is not using it.
I noticed that my color profile seems to disable in most of my games, if not all. However my 2405 was already pretty close from manual tweaking, just a bit red heavy.
Anyone know how to disable (Spyder2 Express) that popup message at startup reminding to recalibrate since it has been xxx amount of time since last calibration?
Start>run>msconfig>startup>uncheck "colorvision startup"Anyone know how to disable (Spyder2 Express) that popup message at startup reminding to recalibrate since it has been xxx amount of time since last calibration?
Hi,
I recently bought a BenQ 241FPW, and I would like to calibrate it with the Spyder2Express. I don't do any photo editing, I just mainly use it to web surf and watch movies. Do you think it would be worth the purchase/make that big a difference for surfing and watching movies? Did I read correctly that the color profile Sypder creates is only usable in Windows? I ask this because I will be hooking up a HD-DVD player and was hoping that the Spyder would be able to correctly calibrate the monitor for that.
Thanks
I would if you watch movies with it. It comes in handy to have a good calibration tool to properly adjust your black levels if anything else. Doing it by eye is a tricky thing and you have to know what to look for. Besides that you are going to get overall better color,etc with a good calibration program. I am not sure how well the express will work because I use the next model up. You get what you pay for.
Those brands should be able to handle most (if not all) LCD monitors. However, I cannot really give a absolute answer. Questions like that should be directed at that company,Question:
I am getting a new 26" LCD tomorrow (Planar).
I have to admit, I bumped into this forum just a short time ago, and simply DON'T HAVE THE TIME YET TO READ IT THRU -- WHICH I WILL LATER, I PROMISE....
But for now...
Before getting my calibration system --- does it need to KNOW the monitor to do the job? Or can it calibrate ANY monitor, even a brand new model?
ALSO: Which of the 2 would you suggest, Spyder 2 or Eye-One Display 2, both just under $200. I tend to go for the second one and that's what I ordered for now (can still cancel it easy)... Thanks!
It should as you should be creating a monitor profile as well as make adjustments to the red/blue/green on your on screen display. However, please be advised I am not sure if the express has the on screen adjustments. I do know that the Spyder 2 Suite does.Thanks for the reply, I'm pretty sure I will be getting it. But do you know if the changes will actually stay in place when I hook up the DVD player to it? I've read the settings only stay in place when using windows.
Thanks
I'm 99.99% certain (going by reviews) that the express doesn't offer pre-calibration of the monitor itself. It's purely done by colour profiles (pretty sure the Huey is the same). You need to go a step up to get that.
re: amikoenig
Tests seem to show the Eye-One Display 2 as being more accurate than the Spyder 2. Stick with it.
