now i bought a dvi cable to connect from my video card to my tv, it hooks up and i get display on my tv... but im having a lot of software based problems, the nvidia software pops up and i try and set my settings the way i want them but its reallly annoying, like all of a sudden the properties windows are on my tv and i gotta drag it over to my monitor, and the tv isnt getting a propper display, its a 65 inch widescreen and windows isnt properly fitting onto it..i hit format on the tv but that only made it worse so havin trouble... i dove into this without reading exactly what i needed to do because i thought it was plug and play easy...heres what i want to do, i want to have the tv set up so i can sit back and game on it from my pc, i dont want any of that dual monitor stuff where i drag stuff back and forth, i want the same image on both screens, was the dvi cable the right choice or should i have gotten this
http://www.newegg.com/app/ViewProductDesc.asp?description=14-999-203&depa=0
i figured since my tv has the dvi hookup that the cable is best but then i saw that, it also has those inputs... im probably wrong but whatever...
anyways please someone help me out...im really discouraged and im thinking of just returning the cable and forgetting the whole idea
