enabling temperature monitoring.GTPoompt said:what were you doing when you trashed it?
navicaph said:Wow, these are some amazing OCs with mind blowing results. I'm not even sure I want to kick down 300 bucks for x800xl anymore...
pxc said:enabling temperature monitoring.
I used debug (+ NVCHK) and NiBiTor, both came out identical in a binary compare. It might be the old version of nvflash that I have. Been too lazy to download a newer one. Going to try again later today. I'm playing with a new cheapier ($75) Celeron D 2.4GHz @ 3.6GHz & motherboard combo now. That might get an AGP 6200 if I find another deal.Ackbar said:Hmm... neither of us had any problems with enabling temperature monitoring. Why did you have to flash so many times?
Edit: NiBiTor now supports the 6200, just use that to edit the bios. Worked for me.
GTPoompt said:I heard somewhere that they might phase out the 6200 AGP for some reason. Or maybe they would crappify it then re-release them.
pxc said:I used debug (+ NVCHK) and NiBiTor, both came out identical in a binary compare. It might be the old version of nvflash that I have. Been too lazy to download a newer one. Going to try again later today. I'm playing with a new cheapier ($75) Celeron D 2.4GHz @ 3.6GHz & motherboard combo now. That might get an AGP 6200 if I find another deal.
The 6200TC uses the NV44 core vs the NV43 core on the 6200/6600/6600GT.Demogorg0 said:By the way, I've heard that these 6200 firmware tricks do NOT work on a Turbocache. Does anyone know if they use a new core?
naw, i think they will just add a bridge chip and disable the TC features. I already saw a new NV44 entry in 76.10.GTPoompt said:hmmm so that means since AGP turbocache cards can't exist (at least I think so) then nVidia will be forced to make a new low end AGP
shadowlord said:I'm wondering if it is possible to unlock the temp monitoring feature on a plain 6600 to?
Do you mean enabling temperature monitoring? The only way to do that is with a BIOS flash.shadowlord said:is it possible to do it with software (driver, rivatuner), i'm a bit afraid of flashing the bios
ragejg said:I'm bumping a bit of an oldie, I know, but I wanted to bring up the following:
Has anyone used a 6600 bios on a 6200 yet?
And doesn't the 6200 lack z-compression or something like that? I could have sworn that nv gave the 6200 the "5200" treatment and made it's AA unusable...
BTW someone reported on newegg that the Chaintech 6200's are 64 bit... bleh...
yes, someone has and it doesn't unlock the pipelines. I think if the 6600 BIOS is padded with 0s at the end to fill up the EEPROM that the pipelines would be unlocked. For example, the 6800GTOs bencome unlocked when the larger PCI-E 6800GT BIOS is flashed because it overwrites the masked VS/quad data. I'll let someone else try that.ragejg said:I'm bumping a bit of an oldie, I know, but I wanted to bring up the following:
Nope, no difference between the 6200 and 6600 besides disabling 1/2 the pipelines. Both cards use the exact same NV43 core. The 5200 (NV34) had a different core from the 5600 (NV31) and 5700 (NV35).And doesn't the 6200 lack z-compression or something like that? I could have sworn that nv gave the 6200 the "5200" treatment and made it's AA unusable...
GTPoompt said:On newegg it says it's 128 but if you look at the pictures the box says 64 bit. (chaintech)
I got my 6200 from leadtek, PCB A01. Unlocked fine, right now have it clocked at 360//660. I might try to push 700 when i get back to school
I forgot do download the 3dmarks from the internet before coming home, so all I had was Aquamark 3 and 3dmark2001.
With my ti-4200, 3dmark2001 ~ 11500 with 6200 its ~ 13250
aquamark went from 21000 on the TI to 40000+ on the 6200.
Unreal tournament (2004) runs over 60 fps on 1024x768 with everything max, Haven't benchmarked but this is by eye. Tribes vengaence runs at about 45 fps with everything on max. official 71.84's Quality with V-sync on. the 76's were a bit faster but there were some problems so i reverted back to the 71's
This was with an AMD XP mobile running at 2.2ghz and 512 mb ram, I just upgraded to 1 gig ram so performance might be higher now (I had big pauses in UT2004 in some maps with the 512 meg ram, they seem to have gone away now). I'll post 3dmark03 and 05 if anyone asks.
EDIT: it seems that AA really bogs down performance though. I was playing KOTR and turned AA up to 4x and it was dipping under 25. But KOTR's engine is probably not optimized very well.
I got a low auto-detect speed when i did the same thing. The core probably has a lot more headroom than you think. This is what I tried:Demogorg0 said:For overclocking, I pressed "detect optimal frequencies", which gave me 353MHZ core speed and 657MHZ memory speed.
There were cheaper systems than that (see the link below for a 8400/P4 3.2GHz/512MB/MCE2005/160GB/etc for $280). The one I mentioned was $314 + tax. No coupon other than the instant discount and free shipping.GTPoompt said:$335?? I've never seen the 8400's go under 600 in the outlet. or was there some big coupon?
GTPoompt said:what was the temperature hack? do you need to flash bios orjust check something off in rivatuner?
I mentioned that i didn't do anything to the card... stock cooling and no ramsinks. 80C is not a problem. The GPUs on these cards can handle up to 130C before they throttle.fscussel said:but no one talks about heatsinks and/or coolers, so I don't know, are you doing those overclocks with stock coolers?
I bought another hot system today in the outlet... 8400, P4 630 (EM64T), 512MB, WinXP MCE 2005, 16x DL dvd burner, 16x DVD-ROM, 80GB SATA, ATI E-Home Wonder TV tuner + MCE remote, etc for $240. I got a RA# for a Dimension 4700 I bought last week since I don't need it anymore. This one is much nicer. http://outlet.us.dell.com/Dispatcher?target=SpecPage&serviceTag=ZRB8EEM7GTPoompt said:snip
GTPoompt said:winfox? Is that the software that came on the CD? I have the leadtek as well, OC'ed at 380/680, and I leave it on all night, no problems yet... doesn't seem hot to the touch either.
pxc said:I mentioned that i didn't do anything to the card... stock cooling and no ramsinks. 80C is not a problem. The GPUs on these cards can handle up to 130C before they throttle.
GTPoompt said:i'll get my temps up on saturday, gotta go home this weekend anyway, so i can get the CD while i'm there... unless you can point me to the webpage that has it
edit: dell 4700 seems good too... got the PCI-E.
GTPoompt said:hmmm downloaded winfox. Won't let me oc through it or display hardware monitoring.... weird.
this is AGP btw
