I think the thermalright Box-1 might be a good choice for watercooling..
http://www.thermalright.com/new_a_page/computex_taipei/compx2008.html
I would buy this, but I am liking the hot swappable hard drives of the X2000
Is it wide enough for a TRUE 120?
The only thing bugging me at the moment is the door... choke your fans FTL
For those of you that find the side-opening opticals would be a good thing, that's great, but I can't see any good in it. First of all, the case is /tall/ and the opticals are at the top, so if it's on the desk the user would probably have to stand just to exchange discs, unless they're built like Stretch Armstrong or Mr. Fantastic. Second, with it being so tall it is much more likely to be on the floor; the side-opening opticals dictate which side of the desk the case can realistically be on, so it won't work in all setups, and I don't think the side the drives open on can be changed.
It looks cool, but the side drive openings are a bad design choice IMO. There should also be more drive bays considering the size of the thing. It's a pretty impractical case.
400$!?!?!?! for the x500.. shit, that sucks. looks like ill be keeping my a05b for while ~_~
i was really looking forward to this case, but at this price its just not worth it to me, i was thinking more like 170-200$
The case is a mid-tower class chassis so no it's not THAT tall. And there are a lot of advantages to having your case on top of a desk instead of down in the floor, regardless of whether it's a mid-tower or a full tower. Down in the floor you get more dust, less airflow, it's harder to access when you're swapping devices because you have to get down in the floor to do it or pick the case up onto the desk, and it's harder to monitor what's going on inside the case. In my instance I have a large flat heavy desk and my tower sits sideways across the back left side of the desk. Having side-opening opticals in my case is perfect because they will open towards me instead of having them opening out in the front and me having to reach to the side of the case in the back.
It's a mid-tower case. You guys are just being awed by some the stretched out pics on Lian-Li's site which makes it look a lot taller than it really is. 2 opticals are more than enough for most people. The majority of people have more optical drive bays than they need. No you won't have the room for all those other 5.25" bay devices that take up like two slots if you're into those but for the rest of us that simply have a couple DVD/Blu-Ray drives and that's it then it's all the room we need. Because of the way it's designed with more room in the bottom compartment you will have better airflow and more room to work with watercooling.
http://lian-li.com/v2/tw/product/upload/image/X500/x500d04s.jpg[/IMG]
The case is not that big. It's just a little taller than your average mid-tower because it's shorter due to everything in the front being taken away and put up top.
Here are some comparison measurements to my Silverstone TJ-09 to give you an idea.
Width = 1" thicker (TYR PC-X500 ) than TJ09
Depth = 23 1/4" (TJ09) vs <15" (TYR PC-X500)
Height = 20.5" vs 23" - TYR PC-X500 is only 2.5" taller than TJ09
So as you can see this case would be perfect for someone that wants to sit it on top of their desk not only because of the side opening opticals but also because of it's much shorter depth it will take up less desk space. And that doesn't even touch the fact that the aircooling should be great in this case due to having two 120mm intake fans positioned right in front of the motherboard with absolutely no obstruction whatsoever.
Its definitely much taller than almost any "mid-tower" cases, despite what li-li says. Yea the short depth is nice for placing on desk but I have a feeling the opticals will be unconfortably high in that setup.
I Agree about the number of drives (I really dont need more than 2) though, and the cooling definitely looks great. I think would sell decently at $300, but is definitely too expensive right now
I love my LL cases but they've certainly jumped up a lot in price premium with their newer cases. Seemed like they used to top out around $220, now they're upwards of $300+. I know the economy is in the toilet and the USD$ rate is pathetic right now, but $300+ for a case...thanks but no thanks.
I think I like this more than the Tj9 and even the 10... probably going to use this for my new gaming box
I will never pay more than 125 dollars a case period. I don't care how cool it is. Hell up until now I've never paid more than 30shipped for one . I'd rather spend that extra money on parts .
The PC-X500 is the mid tower, the PC-X2000 is the full tower. It would be interesing to see what a mini would look like though.I really like the clean front without needing a door to get to the drives. Thats my main complaint about cases with doors no matter how good they look. Downside is I would never get a full tower. If they made a mid/mini with this design I could appreciate it more. Ideally they would use the A05 PSU placement and get rid of "Zone 1" completely. Oh and that price is ridiculous too.
The TJ-09 will probably be my next case.
