Hi - as a test of an idea I was working on - I tried making a simple pounds <> kilograms converter. I had a feeling it was gonna have a problem though - and I was right.
So - the idea is that when you changed the value of one cell, it'd write in the appropriate amount in the other cell. Problem is - that Excel then registers this is a change, so runs the script again. Creating a loop. You can see I put loop counters in A2 and A3 - and they increment by about 100 each time I change a value. How do I fix this?
Sorry - I am more of a C guy.
Thanks!
PS is there an equivalent to C's += operator in VBA? I couldn't find one.
Code:
Private Sub Worksheet_Change(ByVal Target As Range)
If Target = Range("H4") Then
Range("I4").Value = Range("H4").Value * 2.20462262
Range("A2").Value = Range("A2").Value + 1 'demonstrating problem
ElseIf Target = Range("I4") Then
Range("H4").Value = Range("I4").Value / 2.20462262
Range("A3").Value = Range("A3").Value + 1 'demonstrating problem
End If
End Sub
Thanks!
