FYI AI Suite II temps are going to be around 10C lower than core temps measured by tools like Real Temp . . ..
FYI AI Suite II temps are going to be around 10C lower than core temps measured by tools like Real Temp and AIDA64. So probably closer to 74C (not dangerously high but still).
I had similar problems with similar configuration.
What really helped me is that I found info on some website regarding BSOD error codes.
BSOD Codes
0x124 = add/remove vcore or QPI/VTT voltage (usually Vcore, once it was QPI/VTT)
0x101 = add more vcore
0x50 = RAM timings/Frequency add DDR3 voltage or add QPI/VTT
0x1E = add more vcore
0x3B = add more vcore
0xD1 = add QPI/VTT voltage
“0x9C = QPI/VTT most likely, but increasing vcore has helped in some instances”
0X109 = add DDR3 voltage
0x0A = add QPI/VTT voltage
Here is the source, there is more info on overclocking sandybridge.
http://www.overclock.net/intel-general/910467-ultimate-sandy-bridge-oc-guide-p67a.html
So I raised VCCIO to 1.125 and system is stable after 2h in prime, I stopped it after that.
After couple of days no random BSODs everything stable at 4.7ghz.
Have not tried it yet at 4.8 because I would need more vcore. Currently on load I'm at 1.41 - 1.43v
My config:
Asus P8P67
Core i7 2600k
4x2gb 1333Mhz DDR3 TakeMS
Coolermaster Hyper 212+
I tried all options still not stable with prime can you list out your settings and also your dram settings as well...
I tried all options still not stable with prime can you list out your settings and also your dram settings as well... Just FYI my os is Windows 7 64bit
AIDA64 can read and reports ALL sensors, including the CPU package temps.
i am looking at it on my g19 as we speak
The only issue you might see is a lag in polling intervals between AI II and AIDA64. Other than that temps are bang on.
and you do have to go into preferences in AIDA64 and turn on a few that are off by default.
I have a P8P67 PRO and a i7 2600K. I've closely followed the steps of this thread, but i cannot change the multiplier, although, i can change it in the BIOS, all 4 cores for example 38, but when i restart, the speed is still 3400mhz (or 3502, then suddenly it changed automatically to 34 x 103) but that's it.
When i do the Asus autotuning thing in windows it says that multiplier 46 is possible, but when i restart is 34 all over again. I cannot figure it out, can someone help?
(it's a i7 2600K, at least that's what the box from the cpu says (unleashed and unlocked), but also in the BIOS, CPU-Z en windows system says it's a 2600K)
i have decent memory and cooler; at least good enough for a multiplier 35, but even that doesnt work.
Where do you se it reported that it is at 3400? CPU-Z? If so, make sure you have the correct version. What BIOS settings are you using in the AI Tweaker page (or whatever the heck it's called).
Changed:
From manual voltage to offset+ 0.025 gets my particular CPU 1.384v in Turbo
VRM Fixed Frequency - 350
Phase Control - Extreme
Duty Control - Extreme
The other settings outlined above I already had in place. I have 4x2GB Kingston 2133MHz at 9-10-9-27-2t
I'm really happy with the way my system is running. It's nice knowing that my CPU isn't getting full load voltage all of the time, which should prolong its life. I am rock solid at 4.9GHz.
Hey guys, i've got the 2600 with the p8p67 pro and i've got my overclock @ 4.2 ghz with temps of around 50-60 on load
for some reason its still got the auto tune feature on.. so my cpu goes down to 1.6 and back up to 4.2 when im gaming.
I'd like to have it @ 4.2 constant instead of it dropping
any ideas what i need to do to turn it off?
thanks!
can anyone explain how does the cpu offset voltage works, ie the +/- thing?
1. Approximately 50% of CPUs can go up to 4.4~4.5 GHz
2. Approximately 40% of CPUs can go up to 4.6~4.7 GHz
3. Approximately 10% of CPUs can go up to 4.8~5 GHz (50+ multipliers are about 2% of this group)
Has anyone found that after swapping to the b3 board, suddenly (same bios settings), the cpu ratio tab is missing from Turbo evo? Tried removing and reinstalling with the latest version no change.
