massta said:Hello everyone, hope someone out there is running this monitor with another
The software I use needs two monitors.
I usually have my nvidia card set to Horizontal Span when two monitors are detected.
But since the Dell is 16:9, this will be a problem with second 4:3 screen
Is there a way to still run both together?
~Shawn
www.massta.com
DangerIsGo said:Im looking at getting the 2405 at the end of this summer as my friends both have 1 and its huge, i love it, and great for SLI gaming! (As i need a big monitor to take advantage of my SLi goodness that Im about to receive! ) Anyways, ive heard problems facing the 2407 such as backlight banding (or something like that), input lag, etc.. and to just get the 2405 (which i was going to). But then my friend said that they had fixed all that stuff. I read here about a revision A02 compared to revision A00. Could someone please let me know if those issues have been fixed? If its the monitor that everyone hopes it should be? How is the image quality compared to the 2405? And whats the cheapest you can find it for? $800 is as much as Id go for a monitor. Thanks!
DangerIsGo said:Sry to quote myself, but does anyone know if these issues have been solved w/ the new revisions?
rjc said:I'm looking to buy a 24" monitor in August/September, and this is the one I'll probably buy.
So if I had a blu-ray drive installed on my PC, it wouldnt display 1080i via DVI??samnmax said:It has HDCP. Definately works at 720p. Doesn't work at 1080i, since 1080i doesn't work at all over DVI. I haven't heard about anyone testing to see if it works at 1080p.
Krycek1 said:So if I had a blu-ray drive installed on my PC, it wouldnt display 1080i via DVI??
Daggah said:I guess I'll just have to wait until I get home and have my friend let me play around with his 2405FPW. I probably wouldn't be the person to notice if there are minor problems with the display; hell I've spent all this time playing PS2 via my cheapo 21" TV that doesn't even have s-video inputs, so I've been playing using composite all this time.
bigdogn12 said:In my opinion, playing these game systems through this high resolution monitor will result in picture quality that's worst than your composite tv.
If you don't care about component inputs, theres no reason to be worried about the component inputs...if I follow your question correctly.DangerIsGo said:Would these problems concern you (about the component inputs) if you dont care about the component inputs? Cuase id hook up my next gen system to a regular TV or HDTV (when i get one), not this monitor.
Clevich said:i've heard rumours that they're going to be updating the hardware in the 2407's to fix all banding issues, including the ones in the A02's with vertical banding. Hope we can exchange it without having to worry about the 21 day return policy.
Do you actually think that is an exceptable fix for the VGA VSync issue? Don't get me wrong, I love this monitor but Dell definitely has a ton of bugs to address.WHOAguitarninja said:StryderX, when your Vsync is wacked with the VGA, simply turn the monitor off and back on. Fixes it for me every time.
Daggah said:Well for me, I'm a low ranking enlisted person in the US Air Force, so I don't get a whole lot of money to spend...the decision is pretty much between getting a 24" widescreen monitor, or perhaps investing a bit more and going for something in the 30-32" LCD TV range. So if I did get the 24" monitor, I'd want one that I could use for more than just my computer. Hope this explains my concerns.
There is effectively 0 input lag when compared to a monitor running 60Hz refresh rate. Any lag compared to monitors at higher refresh rates is merely due to the refresh rate being quicker.
DangerIsGo said:I was in the AFROTC at my college..but i dropped out :/
? I dont understand. I thought the 2407FPWs had input lag along with the color binding and backlight bleeding, but the input lag was the biggest problem (or was this another monitor?)
SonComet said:My A02 2407wfp came today and it has no stuck or dead pixels. It's not dark enough to test the backlight bleeding yet. The backlight is brighter on the left side than the right, but that is an inherent problem with large widescreen monitors that cannot be fixed. The vertical gradient banding is only noticeable in certain situations. 95% of my wallpapers that have some vertical gradients look fine. The test patterns look ok, you can only really see the gradient if you are lookin for it, or if the gradient is huge (like certain sky shots in some of apple's HD trailers). I've been searching for a monitor for so long that if the backlight on this thing doesn't bleed I will probably keep it inspite of the problems.
Yeah the vertical gradients on ctrl-alt-deletes website are pretty bad. The horizontal gradients on gamespot's background are pretty bad (on multimedia mode they go from bad to atrocious). On the superman trailer when the DC Comics symbol appears the gradient is really bad. On the Ratatouille trailer the gradient in the sky is pretty bad. On the Ridge Racer 7 HD trailer the gradients that were perfect on my old monitor are terrible. MGS4 HD trailers look fine, peaceful warrior trailer looks fine except for one scene with the crowd blurred (which shows a gradient problem, the xmen and narnia trailers had some minor gradient problems if I was looking for it. I dunno if I will keep this afterall. Maybe I will try it out for a week since I ordered it from costco and an return it whenever.DangerIsGo said:So your saying even with the A02, some monitors are slipping through w/ problems?
SonComet said:Yeah the vertical gradients on ctrl-alt-deletes website are pretty bad. The horizontal gradients on gamespot's background are pretty bad (on multimedia mode they go from bad to atrocious). On the superman trailer when the DC Comics symbol appears the gradient is really bad. On the Ratatouille trailer the gradient in the sky is pretty bad. On the Ridge Racer 7 HD trailer the gradients that were perfect on my old monitor are terrible. MGS4 HD trailers look fine, peaceful warrior trailer looks fine except for one scene with the crowd blurred (which shows a gradient problem, the xmen and narnia trailers had some minor gradient problems if I was looking for it. I dunno if I will keep this afterall. Maybe I will try it out for a week since I ordered it from costco and an return it whenever.
Edit: I don't know if this banding is something I can get used to. Any wallpaper or movie with a darker gradient has really noticeable banding. If anyone wants me to I can take pictures of this still existant problem.
Zak said:For what its worth, here's a One Page review with pics that says "Banding" is all fixed in the 2407.
http://www.pcauthority.com.au/feature.aspx?CIaFID=1403
Edit: I don't know if this banding is something I can get used to. Any wallpaper or movie with a darker gradient has really noticeable banding. If anyone wants me to I can take pictures of this still existant problem.[/QUOTE]
Please do, I'm sure many will find it helpful.
