JonDoms said:Hmm got any tools to measure it?
Also what screenshots would you like?
I can work on them tonight.
lightsourcex said:How do you run HDTV?
Do you have a TV Tuner Card?
And if so, do you have to have the special HDTV channels as well?
Dameem said:My man JonDoms, I have a very important question for you.
In this site, http://www.directron.com/pw201.html It says that the Panel Size is 20.1", and it is the only site which i found that thinks like me.
When i looked at your photos, and others websites photos, it's height resembled like a 20.1" LCD screnn, but not it's width, as the speakers seems to be included with the supposedly 20.1" Screen size .
That was obvious when i compared them to photos like the Viewsonic VX2025WM and the BenQ FP202W.
Yeah, I find it actually kind of a turnoff when buying a display. Like, if it has integrated speakers, I'm more likely to consider another display over it. It just ekes cheapness.[CaM]Spoon said:built in speakers... when will they learn?
sethk said:I don't have the Asus, but I do have a 2405.
I would not recommend it for games or movies. There is pretty bad input lag for any games where timing is critical, such as FPS games and RTS games. It has moderate display ghosting and tearing too. You also need a monster video card setup to run 1920x1200 (I have a single 7800GTX). Playing games at lower resolutions is noticeably worse.
Movies arent great either. The video is super noisy (not input related - I'm connected via DVI). The component and svideo inputs are beyond crappy. Overall I'd say the 2405 is really a professional / web browsing monitor. It is not good for games and movies. Lower resolutions look OK but not great for text, horrible for games because blurring looks even worse than usual.
lol, are you talking about the shamrock fight?Dameem said:I don't think i can reply anything useful after what had happened yesterday, for now atleast. I am really depressed and sad, I mean did he had to give him that head bash. Just wanna let you know that I'm really dissapointed.
eclipse2006 said:Can the ViewSonic 2025 do the same HD on the screen with the regular desktop? Like what is shown in the third picture of the original post.
That's a function of the program you use to view your videos.JohnleMVP said:Like can the monitor scale the video no matter what res it is to full screen, 1:1 pixels, or aspect mode like on the Dell 20" & 24" wide screen monitors can.
JohnleMVP said:Yeah, but I need the monitor to have video scaling functions for Xbox 360 over VGA and component.
My Dell FPW2005 does it and even does it over DVI which can be nice too because some people with ATI video cards have had problems scaling with certain monitors like the NEC 20"
It's not always that simple...in another thread there was a debate about the panel used in the Acer Ferrari F-20, either a P-MVA or S-IPS. Widescreengaming forum and tftcentral believe its S-IPS yet other monitor focused sites say P-MVA. A google search brings up about the same number of references to both technologies when talking about the F-20 so who knows? I wish manufacturers would go ahead and list that as part of the detailed specs...meganpepi said:Just some info I thought I'd share in case you haven't come across it before. A quick way of working out the panel used in a monitor is to do a google search and type the model name of the monitor along with the panel you think has been used. You must mention the word "panel" eg. To find out the panel for the Asus LCD we're referring to I'd type the words: Asus PW201 MVA panel and do a google search. If I thought it were an AUO panel I'd type: Asus PW201 AUO panel. Even if you pick the wrong panel you will find out the correct panel when you do the search. I hope this all makes sense - it's way past bed time!
joemama said:It's not always that simple...in another thread there was a debate about the panel used in the Acer Ferrari F-20, either a P-MVA or S-IPS. Widescreengaming forum and tftcentral believe its S-IPS yet other monitor focused sites say P-MVA. A google search brings up about the same number of references to both technologies when talking about the F-20 so who knows? I wish manufacturers would go ahead and list that as part of the detailed specs...
edit- to add to the confusion LG/Phillips makes a P-MVA and an S-IPS panel with the exact same specs..
That's my point..you put "F-20" in that search engine you get P-MVA, however if you use the one on tftcentral you get S-IPS. Doing a google search with "F-20 P-MVA" or "F-20 S-IPS" will both get you results talking about the F-20 monitor. Who is correct?travbomb said:
JonDoms said:^^Hater
The viewing angles are fine. Who fucking sits to the side to use the fucking monitor. Moron.
Don't crap on my thread b/c you have an infurior monitor. E-Penis + 11lventy billion!
joemama said:That's my point..you put "F-20" in that search engine you get P-MVA, however if you use the one on tftcentral you get S-IPS. Doing a google search with "F-20 P-MVA" or "F-20 S-IPS" will both get you results talking about the F-20 monitor. Who is correct?
edit- You are correct that LG/Phillips don't make the P-MVA but what I meant is that LG/Phillips make a S-IPS panel with the exact same specs as the panel used in the F-20 and also the Viewsonic VX2025MW which is known to be P-MVA for certain.
