Hey guys, I'm working with my old Opteron 165 system that I've donated to my parents and am trying to overclock it. Here's my steup:
Motherboard: ASUS A8N-SLI Premium
CPU: Opteron 165 (stepping 2, revision JH9-E6)
CPU cooler: arctic cooling freezer pro 64
Memory: 2 x 1GB OCZ Platinum PC-3200 (OCZP4001G)
PSU: Antec SmartPower2.0 450
I can get the system Prime95 stable for 9 hours at 9x295 fsb but I have to underclock the memory with a 1:2 divider (memclock index value 200 MHz), so DRAM frequency is at 148 MHz. At this underclock, I can set memory at the tightest timings and it's stable.
However if I loosen all the timings and try a 2:3 divider (memclock index value 266 MHz), so DRAM frequency is 198 MHz the system refuses to post. This makes no sense to me as this is the posted frequency of the ram. I know the ram is capable of at least 220 MHz on a 1:1 divider, so my guess it the ram just doesn't like the divider. Here's the settings that won't post for me, any tips would be greatly appreciated.
Memclock index value: 200 mhz
Cas latency (TCL) : 2
Min ras active time (TRAS) : 5
Ras to Cas delay (TRCD) : 2
Row precharge time (TRP) : 2
Row Cycle time (TRC) : 7
Row refresh cycle time (TRFC) : 9
Read-to-write time (TRWT) : 1
Write recovery time (TWR) : 2
1T/2T memory timing : 1
S/W Dram over 4gb remapping : Disabled
H/W Dram over 4gb remapping : Disabled
Hyper transport frequency : 3
Amd K8 Cool'nQuiet : Disabled
CPU frequency : 295
PCI Express : 100mhz
DDR voltage : 2.8
Chipset voltage : 1.6
HT voltage : 1.25
CPU multiplier : 9
CPU voltage : 1.50 (board's max on Toledo core Opteron 165)
PCI clock syncronization mode : 33.33mhz
Memclock index value: 266 mhz
Cas latency (TCL) : 3
Min ras active time (TRAS) : 15
Ras to Cas delay (TRCD) : 7
Row precharge time (TRP) : 7
Row Cycle time (TRC) : 22
Row refresh cycle time (TRFC) : 24
Read-to-write time (TRWT) : 6
Write recovery time (TWR) : 3
1T/2T memory timing : 2
