ok onto some fun stuff... I thought I would do a little leak test outside the box, becuase well, it took me so long to make it, i wouldn't want a little water ruining it.. and since I have never hooked up any water cooling parts ever..... and the next step is to put them in the case.... i thought why not.
hooking them up... filling with some water..
putting it all in a bucket in case it leaks, so i can sleep soundlyknowing it wont be all over the floor
shot from overhead
close up of res.... as you can see, there is a little air still in the top of the res becuase its tilted slighty to the side.. I can say it has an interesting side effect... it sounds like one of those machines you buy that sounds like a water fall, or a babbling brook..it looks like a waterfall as well...
i did have ot make one decision, and it had to do with the res....i read a few reviews on it, and one reviewer (i think it was on procooling) said he didn't like the way the 1/2 barbs had a rubber gasket.. that the plastic barbs weren't made to use it, and they weren't o-rngs, etc,etc.. and i read somewhere else, they decided not to use them... afriad over tightening them, might break or crack the res.... both neither actually tried to use the gaskets....both of the reviews used the white tape method instead... I just didn't want to use the tape.. i was afraid it was bound to rip or shred, and then be in the water, just looking to clog the maze or the tdx... so i tried the gaskets.. them seem to be working fine.. its been on for an hour, no leaks, and i didn't tighten them that hard...
So we shall see...
with the leak test running next to me, it makes me feel like im lot closer to having water cooling!
shot from overhead
So we shall see...
