So i was able to get my hands on a Q6600 for cheap from a coworker. It was never overclocked in the past. I swapped it out with my E6750 (which is going in my HTPC) and I can't get the Q6600 to make it through a few hours of Prime95 without one of the cores erroring out. I started out with everything in the BIOS on auto and just figured i would try a run for the shits and giggles. I recieved an error on one core. Then after setting the voltage to 1.25 i tried again. same problem. I have now upped the voltage (in steps running prime 95 each increase) to 1.4 and still have not had any luck. This system is running bone stock with water cooling. The water cooling is running really slow right now (fans and water pump on lowest settings so it is nice and quiet) and the temps at 1.4 volts get into the 60's under load via HWmonitor. There is an 8800 GTX in the water look as well so that helps to heat it up a bit. However I don't feel that this should result in an unstable stock system.
Setup:
CPU: Q6600 B3
Mobo: GIGABYTE GA-P35-DS3P
RAM: 4 GB GSkill http://www.newegg.com/Product/Product.aspx?Item=N82E16820231145
All other specs are in sig.
The bios on the motherboard was just updated. The system has never had a problem before. Any ideas on whether i missed something?
Setup:
CPU: Q6600 B3
