silentbrain
- Jul 7, 2005
Hey, I hope this has not been covered already, but I think unavailable resolutions are possible with this guide, at least with nvidia.
Tutorial: Adding custom resolutions to Forceware:
http://www.widescreengamingforum.co...2&start=0&postdays=0&postorder=asc&highlight=
I have a 245T and this was the only way I could get to other 16:10 resolutions. Haven't used 1680x1050, but I just added and tested that res in windows and Portal, both worked. 1600x1024 also worked. (only issue was 1440x900, stretched to full screen in windows but does a 1:1 scaling thing in Portal, aligned to bottom right...your results may vary.)
Hope that helps..
Edit: I'm using the Samsung drivers for this monitor, if that makes any difference. Can't remember if other 16:10 resolutions were available with the plug and play drivers. But definitely no resolutions such as 1600x1024. In fact, I think my original options were 4:3 or 5:4 resolutions, aside from the native 16:10 resolution. Definitely weird..
Hope that helps..
