Vaulter98c
[H]ard|DCer of the Month - October 2009
- May 21, 2008
It's a single rail PSU if that matters, to me that seems like the best bet considering
Posted via [H] Mobile Device
I agree to disagree. I have had too many PSU-related issues even recently with well manufactured new parts to be comforted by other people's apparent successes. I would err on the side of the manufacturer's recommendations, but that's just me and my personal concerns. People can run whatever they brung; I prefer to remove unnecessary doubt in complex builds such this one, in order to make troubleshooting an easier affair when it comes to that point, and it will. If the specified PSUs are but a click away, why run non-compliant parts??Using adapters won't affect the amount of current supplied to the board. That depends entirely on the PSU and the board itself.
No offense, but although you may disagree, you're still wrong.I agree to disagree. I have had too many PSU-related issues even recently with well manufactured new parts to be comforted by other people's apparent successes. I would err on the side of the manufacturer's recommendations, but that's just me and my personal concerns. People can run whatever they brung; I prefer to remove unnecessary doubt in complex builds such this one, in order to make troubleshooting an easier affair when it comes to that point, and it will. If the specified PSUs are but a click away, why run non-compliant parts??
No problem Vaulter, I totally understand. Heck, I have two PSUs rigged to get my Skulltrail operational because at the time I purchased it last year, all the dual EPS PSUs were well over $300 not including tax and whatever else. So, in effect I saved at least $150, probably more because I didn't have to ship anything.hmm, good points all. U fortunatley due to lack of funds I'm gonna side with zero on this...
Anyways, like I was saying, I'm siding with zero on this. If money weren't an issue I'd use a server box, but I did this project for 2 reasons.
To play around and learn some things (never attempted a build this large)
And because it will be cheaper to run than the box it replaced (from which the sale money made this an even trade, no extra moneys)
Zero, I don't want this to get out of hand but when someone writes a post like yours it's hard not to be at least minimally offended. It's like pointing out an error in code to someone who has been programing in C for over a decade. Even if there is a possibility in being wrong about this, would you run an $800 server board with adapters if you had a choice? It appears from your adamant tone that you would but for the life of me it escapes my understanding as to the reasons WHY.No offense, but although you may disagree, you're still wrong.
I would not use adapters if I had the ability to use hard-wired connectors. However, if faced with the choice to use adapters or not run a machine altogether, I would not hesitate to use them, because for the reasons which I have already explained, there is absolutely nothing wrong with doing so. I can guarantee you that any issues experienced by a computer while using adapters occurred for some other reason, simply because due to the nature of the adapters we're talking about, it's impossible for them to cause any problems.Zero, I don't want this to get out of hand but when someone writes a post like yours it's hard not to be at least minimally offended. It's like pointing out an error in code to someone who has been programing in C for over a decade. Even if there is a possibility in being wrong about this, would you run an $800 server board with adapters if you had a choice? It appears from your adamant tone that you would but for the life of me it escapes my understanding as to the reasons WHY.
Maybe so, but I can attest to having issues with adapters in the past to the point that I shun them today. In one such case, the board wouldn't power up at all, but when I purchased a PSU with the required power connector it ran OK. This was a dual-socket board. Maybe things have improved today, I can't say with certainty but it makes me think twice about it.I would not use adapters if I had the ability to use hard-wired connectors. However, if faced with the choice to use adapters or not run a machine altogether, I would not hesitate to use them, because for the reasons which I have already explained, there is absolutely nothing wrong with doing so. I can guarantee you that any issues experienced by a computer while using adapters occurred for some other reason, simply because due to the nature of the adapters we're talking about, it's impossible for them to cause any problems.
Well, then either the original PSU was faulty or insufficient, or the adapter was wired incorrectly. Electrically, there is no difference between using an adapter and using a hard-wired connector, aside from adding a bit of resistance to the line which is compensated for by the PSU.Maybe so, but I can attest to having issues with adapters in the past to the point that I shun them today. In one such case, the board wouldn't power up at all, but when I purchased a PSU with the required power connector it ran OK. This was a dual-socket board. Maybe things have improved today, I can't say with certainty but it makes me think twice about it.
16GB is more than sufficient. You should be flying with that amount. I'm managing fine with just 4GB...I'm hoping I can get a 4p 8 stick pattern running, I'll hold on the rest of the ram for now If I can get just that stable
Plus it's not like 16 gigs isn't enough LOL
Any one of the Ubuntu flavors would be a good place to try, especially if you're new to Linux. Maybe standard Ubuntu or the slightly lighter Xubuntu?Any other ideas for Linux distros to try? I've only got CentOS on disk now
Oh, well then you'll be better off than I am even with over a year of light use. The new Linux distros with GUI are pretty straightforward. Something like working in Windows but they have their own way of doing things. I think you should have very little difficulty getting used to it. Give the newest Ubuntu a tryout. I'm sure there are tons of other distros many people could recommend besides the tried and true here. I'm partial to any Ubuntu flavor over other lineages, and would choose one of them for a first try.I've used Linux before, exclusivly com. Prompt, but that was a few years back.
Shouldn't be too hard to get back into it, but we never installed anything so I'll have to get used to that again
With 1 i7/8800GT combo (30k) and my main rig (32k right now) going, I'm going to sell the rest of my GPU's (4 GX2s and plenty of mobos and what not) and buy 1-2 more dedicated i7/8800GT combos
Hope to snag the number 2 spot by early spring!
Any reason why you're switching to SMP? Power savings?I'm going to sell the rest of my GPU's (4 GX2s and plenty of mobos and what not) and buy 1-2 more dedicated i7/8800GT combos
ya, and I'm getting tired of babysitting some of the GPU clients
Plus, 2-3 i7s will pull less than 2 CPUs 3 260s and 4GX2s
That and it gives me more upgrade paths in the future, CPU and gpu
It's all about sustainability
