mentok1982 said:Ooooo.
I like the new colors for cooling solution!
Very easy to read and pretty as well.
Gotta' use those Power Point skills I have polished over the years
Zinn said:meh, it's depressing being at the bottom of that chart! this week when i get my new cooler from Stasis, we'll see if I can bump up those megahurtz a little bit
Bona Fide said:Is it too late to add mine?
Make: eVGA
Model: 7800GT
Driver: 77.77
BIOS rev: 5.70.02.11.XX
Stock clocks: 445 / 1070
Coolbits Detect: 445 / 1070
Usable OC: 495 / 1230
Idle temp: 44C
Cooling method: Zalman VF700-AlCu
HeavyH20 said:Gotta' use those Power Point skills I have polished over the years
dR.Jester said:This is on air at room temp of 82.8F. I have a Lian-Li PC-V1000 case also.
Good? Bad?
BFG Tech 7800GT
That was loading up BF2 @ 1280x1024 with everything maxxed out using 8xAA/AF.
510kut said:just a question... how bad is it if I spike above 70? Like sometimes it'll hit 70-72 when playing games. Its pretty warm out right now so I might bring it down some more until summer is over.
And that's why I'm looking into better cooling... mine tops out at 80cHeavyH20 said:That is not that bad if it is a spike here and there. If you started hitting the 80's, maybe then I would look at better cooling.
dR.Jester said:Damn now I know why they say "every card is unique". My BFG won't even go close to or even above 500 core.
Jodiuh said:Gar!!! The previous 68gt from leadtek came with a honking heatsink, right? So I ordered a leadtek hoping they'd do something other than reference...and splinter cell ct
Leadtek laughin' at Jod... There's some comments on xtremesystems too.
Shapeshifter said:XFX
7800GTX
77.77
Stock clocks: 450/1250
Usable OC: 490/1300
Idle temp: 37C
Cooling method: Stock + 92mm panaflo fan on heatsink.
HeavyH20 said:I would wait at least a week to make sure the card is really healthy before any mods. That way, if it fails, warranty is not an issue. Most electronics fail within 72 hours of constant use if they are defective.
pduan87 said:Aww, had to drop my core from 504 to 498. It looped 3dmark05 for hours and BF2 was also fine but I played some source today and got some flashing.
Russ said:Alright, I just got my system up and running like 2 days ago, so i haven't pushed mey oc all the way, but here's my coolbits thingy. I'm installing 78.01 drivers now, we'll see if it makes a difference in mark05.
Make: XFX
Model: 7800GTX
Driver: 77.50
BIOS rev: 5.70.02.11.02
Stock clocks: 460/1250
Coolbits Detect: 489/1320
Usable OC:4 489/1320 for now
Idle temp: 46C
Load temp: not sure, about 60C?
ThreeDee said:hmmm.... I must have your twin brother
Make: XFX
Model: 7800GTX
Driver: 78.11
Idle temp: 44C
Load temp: not sure
..just puting this thing together , so don't know what max temps or clocks are for sure..
Hey ...good call ..now if you could just get Russ to send me his card ..then my life would be complete .HeavyH20 said:The perfect pair for SLI !
mentok1982 said:TA DA!
The thread is stickied!
Thanks go out to my home boy W1zzard for the hook up.
He knows how to keep it real.
ozziegn said:okay. I'll contribute to this list as well.
Make: BFG
Model: 7800 GTX
Driver: 78.01
BIOS rev: ?
Stock clocks: 460 / 650
Coolbits Detect: 490 / 690
Usable OC: 520 core / 700 mem - passes continuous loop of 3DMark '01
Idle temp: 41C / 61C load
Cooling method: Zalman VF700 air cooled.
HeavyH20 said:No problem GoldenTiger. It is interesting to see what these cards are capable of.
BTW, has anyone seen the new eVGA 7800 GT CO? It is a limited release that you can pre-order, so it does not qualify for the step-up. It soundslike it is built as requested. It comes withe a copper heatsink and clocked to 470/1100 out of the box. Here is a link:
http://www.evga.com/products/moreinfo.asp?pn=256-P2-N517-AX
ThreeDee said:Hey ...good call ..now if you could just get Russ to send me his card ..then my life would be complete .
Russ said:or you could send me yours.
I did some playing around with coolbits today. Didn't try to increase the ram speed much b/c I figured it isn't cooled as thouroghly as the core. Would this be correct? Do you guys usually get a good OC over what coolbits detects on ram?
Installed 78.03 drivers too. Coolbits redetected 487 instead of 489. I tried increasing it over 500, but it didn't like that. Most of the time it said failed the test. However, strangely one time it accepted 507, but not 500-506 or higher than 507. Then when I retested 507 it said it didn't work! So I'm at like 498 or something now. Should I do anything differently?
I've got one! I've got onedR.Jester said:lol, funny to see that nobody has voted Asus.
peacetilence said:My coolbits auto detection is exactly 489/1.28. The same speed as a KO. I wonder if they built in some certain limit because I was able to take it up to 530/1.3 (didn't try and go any higher on the memory) until Coolbits detection came back as failed.
roflcopter said:I've got one! I've got one
It was the cheapest one i could get here in the netherlands.
