I used to, but i couldn't stand looking at the extra dangling wires that weren't being used.Does nobody in here use the front panel audio without a soundcard that runs it? How do you recommend cleaning up that wire. This is mainly for the ds3 board. See my pics on page one to see what I am talking about. In my pics the wire is the thick blue shrink wrap jobbie.
here is my contribution. still need to work on cable management a big and once i push this stock cooler to its limits and get my thermalright bolt thru kit in the mail, my ultra-90 is going back in.
my 120mm intake fan mounted with zipties.
bought the window a while back, originally purchased the case without one when svc.com had the $10 AR deal on them.
looks goodHey all, just wanted to give an update on my Centurion 5 build:
-Cut out the front fan grille so more air gets through
-Moved the HDD to the bottom of the 5.25" bay so theres even less blockage (ghetto mounted on a piece of foam so theres no vibration)
-Reversed the side of the window
-and an original idea by yours truley (painted the aluminum pillars black but masked the inside so it gives it that bezel look like the 5.25" cover:
Don't mind the fingerprints, heh
I don't know if you could do this, but I was wondering if you could cut the wires for the connections not being used to reduce clutter.
Without damaging or cutting any wires, you could probably run a tube of wire loom along the bottom of the motherboard and hide the wires inside....
but otherwise, i have no clue what to do buddy
Good luck and if you figure something out, post some pictures for us
~ AMD RULES
nope, i've belonged to some other forums, but always used AMD RULES. Now i've made this my only forum.....since it is most active and great communitythanks man. I think you had a thread over in another forum... maybe I dunno it's kinda old now. It involved a guy called Spazzy? or Tazzy? he had Starscream in his sig but either way you really inspired me
Any thoughts on what to do with the dead space?
Also I cleaned the filters... looks SO much nicer now.
Mike
I might start a rival CM Stacker Club
i wonder why they are making you do that because I rma'd a few parts last summer which cost more each than your 8800 and i didn't have to sign for them and I was 15 as wellto be honest id say since my 8800 had some problem with it it runs games like crap so tomorrow my rma comes and ups called saying u gotta be 21 at least to sign for it so im pissed off since im only 15 and my parents will be at work tomorrow so idk if ill get it.
